Good job!! Isn't it great to see progress?? Just keep the filter running, and clean it as necessary--the chlorine kills the algae, but it's the filter that removes it from the pool.
Happy swimming, hope you're enjoying your 4th!!
An update.
We lost a little ground, having been away for 2 days. BTW, it turns out that Costco has Chlorox 3 big jugs for $7.35, the best price on any brand that I've found in this area.
pH is 7.5, Cl holding at 5-10 since adding about 3 gal 6% bleach 24 hours ago. Ppm total alkalinity 120, cyanuric acid at about 40. I've added about 12 lb of baking soda, and 4 lbs of borax. I suppose I should raise the cyanuric some given the SWG.
There is no visible algae, but the water is cloudy. I'm filtering 24/7, backwashing generally shows bits of leaves and pine needles from the bottom, which I can't see. Any thoughts? Maybe a flocculant? I know it would be safe to swim in, but not appealing. And as someone (Poolmom?) mentioned, someone in trouble would be hard to see.
The Dolphin is sucking up dead algae - we're switching to disposable bags until things settle down.
Thanks, all!
Hold off on the flocculant for now....with the dead algae that was already clouding the pool, along with the amounts of Borax and Baking soda you've added, just give the filter some time to catch up....if you had a pool full of algae when you started this journey, it's going to take awhile for the filter to get it all out. Remember the POPP!! (Pool owner patience and persistence)
Thanks, Janet!
I keep in memory the first two years we were in the house, when pool maintenance was so easy, and the ease and pleasure of late afternoons by the crystal clear pool....precious memories.... I intend to give it 2 big bottles of bleach tonight, check the Cl after an hour or so, and then again in the morning before the sun hits the water. At least here near Atlanta we can probably swim til the end of September.
I think I'll try some of the DE equivalent in the filter, 1/2 cup at a time to give a 1 lb pressure rise. What's to lose, only some cellulose fiber....
It won't hurt to try. Remember that the pressure rise takes a few minutes, so add a little, give it 5 minutes or so, then add more if you need. If your pressure rises too much you can always backwash it out and try again.
Let us know how it goes
Well, the pool holds Cl overnight. Tests at about 11 AM this morning:
pH 7.2
ppm Cl no bleach added yesterday evening 5
ppm tot Alk 120
Cyanuic acid 30 - 40 ppm (I haven't found locally a proper test kit, I'm using strips)
I've added some calcium carbonate to raise the pH to 7.5 - 7.6
The pool is still cloudy, but no green, even after running the filter 24/7 for well over a week. Any suggestions? Time for flocculant? Any other ideas? This problem is getting depressing....
Did you try the DE? And if so, did you see any improvement? Also, at the beginning of this thread you stated that the pool store had you using "a LOT" of cal-hypo--what's your current calcium hardness number?
Jant
Well, I knew the liner was due for replacement, but I'd hoped to be able to wait till fall. But, after a drop in level of 4 inches in one day....Bwaaah!
I've added flocculant in the hopes of being able to see the bottom so I could check for a leak and patch it, maybe. I've also heard the suggestion of adding food coloring at potential leak points - drain fitting, returns, etc, to maybe spot a leak.
Of course fresh water would let me have the proper chemistry from the beginning. Now if only the SWG cell doesn't fail.
Any other ideas? This summer is turning into a nightmare. At least our insurance covered replacing the roof, thus freeing up money for the new liner. Grrrrrrrrrrrr!
More complications. I suspect a leak in the returns. I'm posting under Repairs.
And the water was clearing nicely....
Thanks for the help on water quality. I'll be ready when the liner/leak problems are resolved.
I hate to hear about the new leak problems--just when you were finally getting the water cleared up!!
Hoping for an easily located and fixed problem, so that you can start enjoying your summer.
