Results 1 to 10 of 17
Thread: Newbie - Green Pool
    Jun 2010
    Kansas City, MO
    Default Re: Newbie - Green Pool
    Thanks for your help everyone. Quick and/or dumb question for you. It looks like the Taylor K-2006 only tests chlorine up to 5.0 ppm. How do I know if I've got the level up to the recommended 20 ppm?
    The K-2006 actually includes TWO chlorine tests: The FAS-DPD drop test we all recommend, and a simpler OTO test that uses a standard Taylor OTO/pH cell. The OTO side only goes to 5ppm for Chlorine but the FAS-DPD test doesn't use the cell at all and measures FC up to 50ppm.
    I think that's the source of your very understandable confusion.
    We are all going to have to remember that for the future! It's so automatic to all of us we don't even think about it anymore.
    You are confusing the K-2006 with the kit that Ben used to sell. The K-2006 does not include the OTO/pH small comparator (which is actually the Taylor K-1000 OTO/pH kit) and uses the large pH comparator with acid and base demand tests.
    Hmmm....Looks like you are right AND I am wrong (What? Did the planets allign or something??? )
    So the question goes back to Ponytailhair: Why did you think that the K-2006 only goes to 5ppm for Chlorine?
    Jun 2010
    Kansas City, MO
    To answer CarlD, I googled Taylor K-2006, and the one I looked at had this summary: "A complete DPD test kit designed for service people, commercial pool operators and health dept officials interested in economy & portability. Tests for Free & Total Chlorine (.5 - 5.0 ppm) Bromine (1.0 - 10 ppm), pH (6.8-8.2), Acid Demand, Base Demand, Calcium Hardness, Total Alkalinity and Cyanuric Acid. Uses 3/4 oz reagents.Plus Titrants to improve accuracy."
    I do not want to break any rules about advertising, especially since I don't even know this company, so I will not say which google result I got this information from.
    This is all like a foreign language to me, so thanks for your patience and help!
    Quote Originally Posted by ponytailhair View Post
    Free & Total Chlorine (.5 - 5.0 ppm) This is the DPD test, not the FAS-DPD TEST
    Bromine (1.0 - 10 ppm) Unless you use bromine instead of chlorine, this is not relevant.,
    pH (6.8-8.2) This tests how acid or alkaline your water is.
    Acid Demand, Base Demand Ignore these two. They sound more important than they are,
    Calcium Hardness Measures calcium and is only important in concrete/plaster pools or when it goes too high in vinyl pool. I measure this once or twice a season since my pool is vinyl,
    Total Alkalinity Loosely, this measure how resistant pH is to change so it doesn't bounce around. It's more than that but that's enough to know for now.
    and Cyanuric Acid Stabilizer: A two edged-sword. You need it to keep chlorine from being destroyed by UV rays. Too little is a problem but too much is a bigger problem.
    Thanks for being concerned but even if you had listed the vendor you would have not been in violation--especially since you are CRITICIZING that vendor.
    Now that sounds exactly like the description of the K-2005 kit. The clue is the K-2006 tests Free Chlorine and Combined Chloramines. You calculate Total Chlorine by adding FC and CC together. The 2005 kit calculates Free Chlorine and Total Chlorine and, instead, you calculate Combined Chloramine by subtracting FC from TC.
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Ponytailhair, what does the number say on the sticker on the top left corner on your kit?
    I ordered a K-2006C kit from Amazon (sold/shipped by In the Swim), and it was really the K-2005C... It was mislabled on Amazon (and I'm sad to report it still is!!! even after I spent the time to explain it to them and they had to deal with my return/credit as they don't stock the K-2006 or the K-2006C).
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    sturev's Avatar
    May 2010
    I think I misunderstood your post... I read it like you had the kit and were asking a question about it's use... It appears that you don't own one yet?
    Evan S.
    I think you are confusing the K-2006 with the K-2005 since the K-2006 does not use a comaparator but is a drop counting test.
    The k-2005 is the testkit that is usually carried in stores since it is a bit less expensive (the kits are identical except for the chlorine tests.
    The chlorine test in the K-2006 is far superior and easier to use so this is the kit you want. In most areas of the country it is not stocked so you will most likely have to order it online.
  1. Green, green, green and running out of patience.
    By marciastz in forum Dealing with Algae & Slime
    Last Post: 06-12-2012, 11:51 AM
  2. Livestrg05 - Newbie question about switching types of chlorine in green pool
    By Livestrg05 in forum Dealing with Algae & Slime
    Last Post: 04-21-2011, 04:55 PM
  3. Newbie w/ very GREEN pool - HELP!!!
    By gettinthesplash in forum Dealing with Algae & Slime
    Last Post: 09-03-2010, 12:04 PM
  4. Newbie's green pool
    By George in Georgia in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2010, 03:21 PM
  5. green pool: like black/green pool
    By bazman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2010, 10:25 AM
