Hi everyone,
I seem to have a water leak somewhere on the suction side of my pool equipment. I can see air bubbles in the clear lid that is attached to the pool pump.
I tightened the cover to the clear lid, tightened all union connections but I still cant figure out where air is getting in.
I've got two areas that I suspect:
1) The jandy 3 way valve has a broken grease cup thread stuck in the hole and I currently have a piece of duct tape over the hole cause I know it is sucking/leaking water.
2) The elbow coming out of the pump that is connected to a rubber hose that feeds water to the DE filter. The way the pipes are plumbed, the elbow cannot be screwed all the way in because it doesnt leave enough room to slide on the rubber tubing and clamp. I have it threaded most of the way and silicone caulking all around the elbow forming a seal. As of right now I dont see any water leaks or hear any hissing so I dont think this is it.
I have a picture of my setup, but I cant post any attachments.
