Putting CYA in a sock is a recommendation that we've been making on this forum for years, even before the other forum that you're alluding to ever existed. We do not recommend it as the sole way to add CYA; however, most of the people we have this discussion with are also having filter issues, and that's why the sock is being recommended. We may have gotten lazy about pointing out the other methods, but I remember as many posts instructing people to put it into the skimmer and not backwash for a week as I do about putting it into the sock.
Many of the labels on CYA containers (at least around here) instruct users to broadcast it directly into the pool. Personally, I have a problem with this method. I also hesitate these days to have people put it into the skimmer if I'm not positive that they'll dilute it first--I have firsthand knowledge of a pool where too much CYA was put into the skimmer all at one time and it formed a plug in the pipes, resulting in broken pipes and concrete replacement. So...I'm not sure what about this is bothering you, but CYA in a sock is a perfectly reasonable way to get it into the pool. Not because it's the only way, but because it's really the easiest.
