22k gal pool with cloudy water 5 days after opening
opened pool 5 days ago, checked chemicals readings
21750 gal. vinyl inground pool:- FAC 2 ppm
- TAC .2 ppm
- PH 7.4
- TA 66 ppm <= bogus reading
- CH 161 ppm<= bogus reading
- CYA 74 ppm<= bogus reading
- salt 3000 ppm
After getting all readings to this point , I have been trying to shock the system to get rid of the hazy water,
I can see the bottom drain in the 6 ft deep end But can't get the Chlorine level up to at 4+ to rid the hazy water, on 4 different days I have 2 lbs shock 4lbs shock, and 2 gals. of chlorine leaving pump run 24/7, SWG set 75% ,cartridge filter.
So How Do I get the chlorine up and get rid of the hazy milky water
thank you.
[edited for clarity - PoolDoc]
