Backwashing/Vacuuming--water coming back into pool
We have a Baquapure sand filter and just replaced the entire lid/multiport valve assembly (with a new spider gasket) and changed the sand. Now when I backwash or vacuum the pool, water is coming out the waste adapter plus coming back into the pool. The water only shoots out of the waste adapter half as far as it used to. The algae I'm trying to sweep from the pool is coming right back in. Does anyone have any suggestions? We're not sure if it's something with the spider gasket or possibly one of the laterals. Any help would be greatly appreciated! It's in the 90's, and I really want to swim! :)
Re: Backwashing/Vacuuming--water coming back into pool
Something in the Multivalve assembly is either assembled wrong or the new assembly is defective. I doubt it could be much else unless it's plumbed backwards.
CarlD--thank you so much! Your suggestions prompted my husband to check the connection of the hoses to the new multiport valve assembly. When he changed the multiport valve assembly, he reconnected everything exactly the same as it originally was. However, for some reason, the manufacturer reversed the position of the connections. So it was plumbed backwards, and we really thank you! It's time for me to vacuum the pool now so we can swim :)
That's what we like to hear. Simple and CHEEP solutions. Welcome to the forum.
Al - What are you, a bird??
Poconos
Thank you, Poconos! We were thrilled that this was a simple and cheap solution!!
