Robotic versus other Pool Cleaners
I've been a pool owner for about 2 years, so I'm kinda new to the "sport". However, I have been a chemical engineer with numerous related "unit operations" experiences from managing a polyethylene plant that operate at 20,000 psi to designing a wastewater treatment system that use crushed limestone and horse troughs to effectively neutralize an effluent stream. I think I have some practical and technical experience that relates to pool ownership.
So two weeks ago I bought a robotic pool cleaner, the AquaVac Tiger shark QC. The reasoning for my selection was: Internet searches, including poolforum.com, seemed to indicate the two preferred pool cleaning systems were either a pressure-side system such as the Polaris OR a robotic system. I didn't already have the booster pump or wiring that a pressure-side cleaner requires. I could have easily installed the pressure-side system myself but the cost for the robotic and pressure side systems would have been about the same and the robotic system would not put trash into the pool filter that would have required backwashing to remove. (I had been using a suction-side unit, a 10-year-old Kreepy Krauler that I inherited from my original pool user. When the suction plate and regulator for the Kreepy died and would have required $150 to replace compared to a new Kreepy for $250 (that my wife though was inadequate but I pretended was OK) a change was eminent.
Of the robotics, I chose the AquaVac Tiger shark QC because it used filter elements rather than filter bags. Internet searches indicate that cleaning the filter bags is a real drag and the filter elements are supposed to be an improvement. The QC also has a 60-minute cleaning cycle. Normally my pool stays very clean with little cleaning, so I hoped that the 60-minute cycle with the QC would be enough. I also believe that if the unit only has to operate for 60 minutes rather than 5 hours, the machine will experience less wear-and-tear and should need less maintenance.
So how has my decision to buy the AquaVac Tiger shark QC worked out? I have operated the unit twice. Some debris was left in the bottom of the pool after both cleanings. The pool cleaner, as least so far, has not offered to bring me adult beverages. The jury is still out. However, I did not make the decision without much thought. We will just have to see.
re: Robotic versus other Pool Cleaners
I recently purchased the Dolphin Dynamic and very much appreciate the cleaning tip in the prior post. This robot cleans pretty good. The only thing that bothers me is that it tends to "blow" the leaves out of its path before running over the area. My pool water is currently about 65 degrees. Will this work better in warmer water? Are there any adjustments, e.g., increase in suction power, etc.
Had an Aquabot Turbo... Sold It and Purchased a Pool Rover Plus
Both made by the same company:
http://www.aquaproducts.com/apsite/index4_22_05.htm
While other folks have found the Dolphin/Aquabot effective and trouble free, My experience with the Aquabot Turbo was less than ideal. I have a 26Kgal vynil liner pool. (L shape with stairs on the "foot" of the L). For my pool, The Aquabot Turbo was far from drop it in overnight and forget it:
It would climb the walls to the waterline, eat it's own cord and get tangled up
get stuck in the corners, stairs, ladders
get stuck and spin on top of the main drain (there's an $80 cover for the main drain that allows the robotic cleaners to navigate it).
After futzing with the cleaner for ~2 months, I gave up and got the Pool Rover Plus (at ~60% of the cost $475 shipped) after a reading review posted on this forum prior to it going down. I absolutely love this cleaner. It's just so ridiculously simple (just makes timed K-turns). No microprocessors, No cicuit boards in oil bath, no tracks/brushes... SIMPLE! And since it's the same impeller/filter bag design (in fact the same filter bag as the Aquabot Turbo) you get all the "water polishing" benefits. Plus it's a 2 hour clean cycle NOT an 6~8HR overnight cycle. If I really want the water to sparkle, I run it 2~3 cycles for a deep clean. It's pennies/cycle to run this cleaner. I actually don't think I need to run the pump/filter ($1~2 for an 8HR cycle) on days I do the deep clean. You should see the stuff it pulls out of even the cleanest looking pool
Now it doesn't scrub or climb walls to the water line (it'll climb the hopper ramps and almost go vertical). With a plaster pool perhaps the scrubbing/water line cleaning is a big benefit. But with a vynil liner I personally think NOT scrubbing is a PLUS! Why prematurely wear out the liner? I much rather run the brush manually over the walls at the start of the cleaning cycle.
If you have a vynil liner pool, check out the Pool Rover PLUS (Plus is for IG pools).
