Re: Combined Chlorine Issues
Hi, and welcome to the forum!! We're glad to see you here.
My first question is--what method are you using for your testing? The reason I ask is that it is almost impossible to go from a CYA of 30 to 0 with clear water. Normally when CYA breaks down into ammonia, it is because an owner has let the pool go into a thick, green swamp. In any event, there are ammonia tests, similar to those you use in aquariums, that you could use to check your ammonia levels.
You can go ahead and add your CYA, either by diluting and putting it into the skimmer slowly, breaking up clumps, and let it dissolve in your filter (don't backwash or retest for at least 4-5 days if you do it this way) or put it in an old knee hi or tube sock and hang it in front of a return to dissolve that way. Check the owner's manual for your SWG--most of them require a CYA of 60-80 ppm in order for the SWG to work as efficiently as possible. Since CYA dissolution is a gradual process, you can go ahead and shock the pool at the same time. For the time being, I would get it up to at least 15 ppm, but in a plaster pool it wouldn't hurt to take it up to 20 and hold it there until you have no chlorine loss overnight and your CC is less than .5. Of course, as your CYA level rises, so will the shock level (see the Best Guess chart at http://www.poolforum.com/pf2/showthread.php?t=365).
Thanks for the Reply.
I use Lamotte ColorQ Pro 7 test kit. It has always been fairly accurate and I have never had any problems with the numbers. To test for FC above 10, I use the shot glass method. I use chlorine neutrilizing drops when testing pH and Alkalinity at high chlorine levels.
I already have my FC at 20. It was at 40 or more for 4 days already. So you think I should just keep it at 20 or higher for a longer period of time.
I think I will wait on adding the CYA until after my CC is eliminated.
Thanks!!
Try keeping it at 20 for another couple of days. There have been lots of reports this year of unusually high chlorine demand, as well as unusually high CC's. Don't know why this is suddenly happening, but the only thing you can do is keep hammering it with chlorine until you eventually break down the CCs. How much chlorine loss do you have overnight? (By that I mean testing after dusk, then again in the morning before the sun is on the pool). Anything swimming in it at night that you know of?
I'm having a little chlorine loss at night. My chlorine levels have been so high, it is more of a guess at how much chlorine loss I am actually having. But, I am having some.
Hopefully, nothing is swimming in the pool at night. On second thought, maybe it would be fun to having something swimming in the pool overnight.
I do have a pool cover that I use. I have been leaving it partially open to let the chloramines air out at night.
Thanks for your help!!
After reading some posts on the Lamotte Color Q Pro 7 and some issues with testing accuracy. I went ahead and purchased the Taylor K2006 Test Kit. I ordered online so I probably will not get it for a couple of days. I will keep my chlorine levels above 20 and then repost when I get the new test kit.
If I should be using higher chlorine levels, someone please let me know?
If your CYA is really zero, then Cl at 20 ppm is fine. See the best guess table stickied at the top of the Chlorine forum...
However, with a plaster pool if you want to go higher, you can.
I should receive my new test kit this coming week.
Here are my current readings today. I have kept the pool at 30 PPM FC for the past week.
FC: 30
TC: 32
CC: 2
PH: 7.4
ALK: 100
CA: 320
CYA: 11
I'm still having chlorine loss at night. I really need some more advice on whether I should kick my FC level even higher or just keep maintaining a level of 30 PPM and waiting until I have no more chlorine loss.
I've kept the chlorine this high for 2 weeks now with no success on getting rid of CC.
Thanks again for any help
How has your cya changed so much over the life of this thread --- 41, 30, 0, 11. (I'm not even sure how you could discern a reading of 11.)
Regardless of which number is right, a shock level of 30 is plenty high enough. Are you letting the cl level fall off during the day or sustaining it with frequent testing and frequent dosing with bleach?
I'm sure it seems as if this is never gonna end. We have had several posters this year with this same problem --- excessive chlorine demand and taking a ton of chlorine to finally rid the pool of CC and have FC hold overnight. But, it does finally get there. I hope you have been reading some of those other threads and get some hope for your pool when you read of another person's pool that has made it through. I'm sorry it is taking so long ................ :(:(
I'm using a Lamotte ColorQ tester currently. So, it is a digital reading. I'm not sure how accurate the CYA readings are. I'm pretty sure the zero was a false reading. But, I'm positive that I have lost CYA over the past month, because it was reading 40-50 all my testings before my CC trouble occurred.
I did order the Taylor kit recommended here, but I will not receive it for a few more days.
Ok. Smart move. Post with your numbers when you get your kit. In the meantime, keep at it. Bleach, bleach, and more bleach.
Received my Taylor K2006 Test Kit yesterday. My Lamotte Color Q was giving me false readings.
Chlorine Numbers with Taylor kit:
FC: 18
CC: 0
Chlorine Numbers with Lamotte Test Kit
FC: 15.5
CC: 3.0
I'm going to let the chlorine get back down to below 10 and then repost all my numbers with both kits for a comparison.
OK. We'll take a look when you get current numbers. How ya like that kit? ;)
Here's my numbers with the new Taylor kit
FC: 6.0
CC: 0
PH: 7.0
Alk- 90
Ca- 500
CYA - 30
Numbers from my Lamotte Color Q
FC: 6.5
CC: 1.8
PH: 7.1
ALK: 86
Ca: 260
CYA: 26
I currently aerating the pool to get my pH up to 7.4.
I'm also going to buy some more CYA and add to get my CYA up to 60 because I do have a Salt Water Chlorine Generator.
I know the Lamotte tester is giving me a false CC reading. My guess is the Calcium Hardness reading is also false. Let me know what you think.
Thanks for all your help!!!
I believe that the Ca reading is also false--if you'll search through the forum, there was a discussion a couple of years ago with another poster on the subject, and involved calls to customer support through the Lamotte supplier, and for some reason that Ca number was false, too. Do some searching and I will too, to see if I can come up with the link.
Otherwise your numbers look pretty good, if you can get that pH up a little!
Edit: here it is... http://www.poolforum.com/pf2/showthr...hlight=Lamotte
Jan, you have a good memory!
I read the article on the Lamotte. A lot of the same issues I was facing with mine.
Thanks Everybody. Pool is in great shape now. I should be able to keep it that way now with an accurate test kit.
Great!! Now enjoy that pool!!
Happy swimming.....
