Re: Newbie Lighting Question
Well, this mornig I got the level down to where I can work with the niche. I took the screw out & it seems that did nothing. I think the previous owners had the trim ring plastered into place. I was going to get a picture, but was running late.
I'm sorry that I can't help with your problem. Trust me --- you don't want to be taking any kind of electrical advice from me!! Not unless you want curly hair (at the very least!) :eek::eek::eek:
The part of your post about being a DIY guy because of the size of your pocket book --- we can all relate to that. That is one of the great things about the Pool Forum. Everybody helping each other out which will usually save a lot of money!
Just wanted to pop in here and say hi and welcome to the forum. Sit tight. Someone who can help you will be along shortly I am sure!
Well my saga continues. Here is where it is now for those interested.
I chipped away & removed the niche. It was indeed plastered into place. I got it all apart to the point where I have deduced that it is the actual socket itself. I am going to kepp taking that apart to see if I can replace that. If not, I guess I am going to have to throw in the towel.
Thanks-
Dave
Bumping this up to see if someone can give Dave some help.
I opened up the fixture, wire brushed the contacts, & volia, it works.
Now the fun part of putting it back in.
Now, aren't you glad you decide against throwing in the towel? Glad you got it working. Get it back in and then ...... go swim!!
Just wanted to jump in and add my welcome to the forum--I know less than Watermom about electrical applications around the pool so didn't dare try to offer any advice, but I'm glad you got it working again, and your post just might helop somebody else in the same position!!
Glad to see you here...
Oh, no, Janet. It isn't possible to know less about the electrical side of pool installations than me! I'm at the bottom!
While I know quite a bit more than either 'mom or aylad about electricity and electrics, I know almost nothing about full voltage pool lights. Glad you have GFCI on it! I'm a big fan of the newer low-voltage lights. I have ones where the lens is part of the pool wall and you access the fixture from outside the pool.
Mojo,
While you have it apart, I would suggest you look into replacing the bulb with an LED. They are cooler, last longer and burn less juice. Best of all they fit in a standard socket. I did it and have been very happy with the results. I even got one that changes colors and the kids love it.
