Re: Famous Chlorine-to Watermom
Have been gone from Western Pa for over 10 days thus the reason no reply .Im now ready for help and to become part of the BBB user group. Pool is inground 21500 gals-DE-Vinyl lined.Is crystal clear but still cannot get a good chlorine reading. I have purchased a HTH Chemical Test kit so here we go. Yesterday after being gone 10 days took readings with kit
Chlorine 1.0 PH 6.8 Total Alkalinty 170 Total Hardness 220 CYA 40 My readings
Free Chlorine 0 Total Chlorine 0 PH 6.5 Total Alkalinty 186 Total Hardness 205 CYA 110 Phosphate 2000 - Pool Store 1
Free Chlorine .3ppm Total Chlorine 1.3 ppm Combine 1.0 PH 7.1 Hardness 190 Alkalinty 182 CYA 60 -Pool store 2
So you can see all on the same pool water with no treatment between some difference
I added (1) bottle of Phosphate remover but as comared to when adding a bottle initially 4 weeks ago the filter never really loaded up .I question the 2000 reading
Today added 1.5 gals of Muriatic Acid and nothing else.Water still clear and up to 80 in temp ,Side Chlorinator is on and loaded with 3 inch tabs.Took another reading with my kit just now
Chlorine 1.0 PH 6.8 Alkalinty did drop from the acid 120 Hardness 240 CYA 52
Everything is clear but still issue of the chlorine reading.
What additional info do you need to assist ? The pool store 2 try to get me to switch to Pristine Blue .I prefer after reading to try the BBB. Wait for your reply
Re: Famous Chlorine-update 5/28
ok all my helpers update from where I am now.
By aerating assume you mean running pump 100% with cover off ? Have been doing
Have shutoff the chlorinator so no tabs in the system
Yesterday morning added (1) 4lb 12 oz box Borax and (4) 1.42 6% Bleach
Checked at 4:00 and the ph was still very low which is what you all had concern. Added another 4lb 12 oz ------------ 2 hours later still low PH . Added another 4 lb 12oz last night
Check this morning as pump has been running all night using my kit
Chlorine .5
PH 6.8
Alkalinity 170
Hardness 210
Using test strips I had the PH actually might just be approaching 6.8
Does all this make sense ? Assumes as you all had concern my PH was extremely low and after adding almost 15 lbs of Borax still is low . Assume getting PH is still the priority .Out of Borax so will wait for feedback then make a run.Have 3 Bleach but will also hold waiting advise.Water is still crystal clear and with warm PA weather my pool is 82 .Never this early this nice in Western pa
Waiting for next steps
Re: Famous Chlorine- misunderstood
I did use a brand new HTH 6 way test kit with the reading of 6.8 this morning .I just used the strip to see what they showed . So will go get more Borax and hit it again .What do you think on Bleach - will add the (3) 1.42 I have so 4.2 gals
Re: Famous Chlorine -where is end?
Went to pool place this morning to have them read a water sample:
TDS 1100 CYA 110 Tot Chlorine 0 Free Chlorine 0 PH 6.5 Total Alk 166 Tot Hardness 209
My readings were:
CYA 60 Total Chlorine .5 PH 6.5 Alk 210 Hardness 180
I added (2) of the Borax boxes and yes another 4 (1.42 gal) of the bleach 6%
Just checked after running pump for 4 hours
PH is above 6.8 but not a 7.2 as that is the range on my HTH kit.So 6.9-7.0 Gained but will need to add some in morning after another run to walmart
Total Chlorine at best 1.0--------------- Why am I not seeing the increase in Total Chlorine?
My kit only reads Total Chlorine-any advise?
Water could not be any clearer . So now what ?
You need a good test kit. We recommend the Taylor K-2006. This place seems to have a good price for it. http://www.amatoind.com/taylor-k2006-test-p-555.html
But, in the meantime, while you are at Walmart, see if they have a 5 or 6-way kit for about $15? Test and post.
By the way, cya of 100 is really high and is going to cause you to have to run higher than normal cl levels. The only way to lower it is to do a partial drain. If you drain half, that would put it at about 55 which would be much more manageable.
Re: Famous Chlorine- update 5/30
Ok added 3 additional boxes of Borax to raise the PH .They love me at Walmart
Finally today have success on PH as am at 7.2 --------------YES
Went back to same pool store today to test and they provided the readings on left with mine on right using the Walmart kit
CYA 70 (why did they get 110 yesterday?) I am out of chemical for this but I have been 50-60 . Assume this will impact what you tell me to do ?
Total Chlorine 0 Me 1 My kit only does Total .Will order Taylor in morning
Free Chlorine 0
PH 7.1 7.2 Me
Total Alkalinity 191 210 me
Total Hardness 229 210 me
They also said phosphates at 2500 and wanted to sell me phos out
My water is sparkling and 82F -never this way on Memorial Day in Pa
I added no bleach today - so GROUP what now as still cannot get a chlorine reading?
Another nice day on tap Memorial Day .
I tried to get a second pool store reading which is 11 miles away but closed .Nobody open now until Tuesday
Looking for advise
Read the following thread. I'm wondering if you are having the same type problem as that guy. Sometimes pools have huge chlorine demands upon opening. That is what this guy's problem has turned out to be. I'm wondering if your pool is having the same thing going on.
http://www.poolforum.com/pf2/showthread.php?t=9547
We'll get this figured out one way or another.
Now that your ph is above 7.0, I want you to start aerating to make the pH rise. (Aim the return jet upward to create as much bubbling and splashing as you can get.) The reason I want you to do this is because your alk is high. Not critical but when your ph gets up to about 7.6-7.8, we're gonna work on your alk. But, that is not a priority for now.
Keep adding bleach. What is the most bleach you have added at one time so far?
Glad you didn't buy the phos out.
Re: Famous Chlorine- History and info
ok yesterday added what was in the 20ppm range of bleach 4 times plus aearate the pool 24x7
Today as requested dug up history which which was way to attach a Excel sheet but here goes and hopefully some answers that will help you guys and gals solve the issue.
Date CYA PH FC TC Alk
7/09 7 6 6
8/8/09 151 7.1 1.3 1.3
8/22/09 125 7.1 0 0
8/23/09 125 7.3 0 0
So it appears my CYA was very high in 09 and I closed with 0 CC 0 FC .I would have closed around Labor Day .Not sure why it drop from 151- 125 but looked like had some issues that went to pool store two days in a row
Now for 2010
Date CYA PH FC TC Alk Hardness
5/14 55 7.1 0 4.2 203
5/16 56 7 0 9 197 Water was somewhat cloudy and thus went to pool place two days in row. Would have done normal start up with shock and algacide ,metal out plus phos out.Using 3 inch tabs tri chlor is side chlorinator. Did the recommended triple shock every three hours for one day or 6 bags of shock each time .Then left town as emergency in SC
5/25 110 6.5 0 0 186 Here is when added the murtaic acid
5/29 110 6.5 0 0 166 Started the Borax and Bleach between 5/25-5/29
5/30 70 6.7 0 0 191 Continued the bleach and borax
5/31 70 7.0 0 .5 210 Aerate,4 applications of 20 ppm bleach
6/1 78 7.0 0 0 210
Test kit OTO so can only measure TC .Ordered the K-2006 last night . Cannot do bucket test because no FC test kits
Reading threads it appears I had a issue with high CYA and TC-FC CC last fall at closing but when opening the CYA was at 55 .Thus as thread stated this means the CYA was converted??
So any thoughts on what to do other then wait for test kit? I will add Borax today for the PH
At the pool store 4 out or 5 people complaining about no chlorine readings.They are pushing Caribbean Blue product . wow
await a reply
Gary
Re: Famous Chlorine- NOW A SECOND PROBLEM-HELP
Received my Taylor Kit tonight and so went to the pool immediately to gather the data .
PH 7.2 FC 0 CC 26 (Does this make sense???) CYA 75-80 Alkalinity 250
Have not done anything since two days ago when posted the history and expected more comments ,just waited for the Taylor Kit
Yesterday my stomach was sick when removing the solar cover . Had been running the eye ball return pointing up to aerate and raise PH .My liner was badly wrinkled and I mean badly .It is about 10 years old .So my theory and it varies:
1. Had had issues in the past when using the eye ball on my return is that it restricted flow and somehow pushed water between my liner and the hard bottom. Thus I assume that what I now see if a accumulation of water between the liner and the hard bottom ?
2.Bleach damaged the liner
3.maybe both?
I go back and forth as did open up my liner and installed a vacuum cleaner to back side and started seeing if can remove the water. Some success but still a long way to go. To say the least the eye ball is off . Today was tied up all day with very sick 86 year old mother so know time.
If it is water will it eventually soak through the hard bottom? Any options or suggestions other then punt?
I have also contacted through one of your attachments the pool supply in Stamford Ct and sent a sample to have them do a chlorine demand test .Should have the results Friday on both my pool water and the city water incase it makes sense to partial drain
So looking for advise on the liner and also comments on my reading? Will do the other bleach test in 2 gals in morning
HELP -READY TO GIVE IN
I am so sorry that after you posted the history, nobody got back with you. If that happens again and you haven't received any replies after 24 hours, please bump your thread back up so it gets noticed.
Right now, we have SO many new posters on here and thus SO many threads and various problems that it is easy for a thread to accidentally be overlooked. So, again, we are sorry.
Glad you got your kit. That is good news. However, why don't you try the chlorine test again. It is unlikely that your CC is 26.
After you get new chlorine numbers, please repost. The new kit is going to make this process a lot easier. You have to slam this pool with bleach. Hard and often. As often as you can, test the water, and each time add enough bleach to get back to a cl level of 20 ppm. There is no such thing as testing or dosing it with bleach too often. Really. The more often you can do it the faster this is gonna go. If it were my pool and I had been struggling with it for as long as you have I think I'd be testing it before work, come home at lunch and test if I could, as soon as I got home from work, a couple hours later and then again before bedtime. If you have somebody who can do it mid-morning and mid-afternoon for you, even better. Don't give that chlorine level a chance to drop. Sustained high cl readings are all that is going to work for your pool. And, run the pump 24/7 right now. Watch your filter pressure.
PH of 7.2 is ok. Actually, while fighting algae, chlorine seems to work best when the pH is a little on the low side --- but just don't let it drop below 7.0.
I can't really advise you on the liner problem. Hopefully someone else will see this and chime in. Or you may want to start a new thread in the pool repair forum just to address that. I think you may get more views from some of our builder/installer type of members in that forum than you might here.
Bleach will not fade a liner anymore than any other type of chlorine will. Liquid chlorine sold at the pool store is typically 10 or 12% sodium hypochlorite while bleach is only 6%. Everyone assumes bleach will fade liners because they associate bleach with fading or bleaching clothes. It is no more likely to do so than any other form of chlorine.
Hope this helps some. I know you are frustrated, but don't give up. We will stick with you til you get this solved.
EDIT -- Just now re-read your post and noticed your sentence about your ill mother. Sometimes pools are not priorities. This may be one of those times. If you have to wait to focus on the pool at a later time, we'll still be here to help you.
Re: Famous Chlorine-Results Chlorine Demand Test
Received my call on Friday from the sample sent in to have a chlorine demand test completed by Par Pools . The numbers matched up pretty good with mine as they had PH of 7.1 FC 0 CC 0 Alkalinity 186 and CYA of 80 . They tested the city water and the good news it is acceptable to use as fill. Their analysis shows a severe chlorine demand and a calculation of 78 lbs of shock would be needed. So like a few messages back the recommendation is to do the partial drain. Started yesterday. Hopefully can start refilling today . Will post .
Will attempt to suck back liner when level is down to see if wrinkles can improve
Thanks for all the advise as "FINALLY HAVE CHLORINE " . The chlorine demand test done by Par Pool and Spacs was a huge help as it showed the best approach was partial drain . This was accomplished and a second test done showing a need to one time shock with 12-14 lbs which was completed Friday .Gone for the weekend and it was 90 all weekend in full sun.Returned last night and readings
PH 7.3 FC 2.6 CC .4 Alkalinity 210 Hardness 220
Chlorine reading has held and wowe does that Taylor Kit really make it easy .
Question for Watermom and others- should I be concerned about a Alkalinity of 210 and if so what is best approach to drop it ?
Also since adding heater years ago get into a issue with stains on the white steps and around the skimmer.I have learned the trick of Vitamin C . What do you recommend to treat this ? Metal Free or something else???
Thanks again
Yes, alk of 210 needs dropped. We have a "how to" for lowering alk at this link:
http://www.poolforum.com/pf2/showthread.php?t=191
Also, read this sticky about stain removal:
http://www.poolforum.com/pf2/showthread.php?t=7923
Read these and see if they help. Really glad the excessive chlorine demand is over. Now time to enjoy the pool!
