Hello, I have a 3 year old in ground plaster pool. It is 30000 gallons. I am running a Autopilot dig-220 SWG. My problem is a constantly rising CH.About 1 year ago I had the harness at 600, so I decided to drain the pool and refill. When I was done and got the chemicals back in balance it was down to 200 CH. Now once again I am at 550 CH. Any ideas as to what can be causing this? My fill water is fine. A whole other issue is my constantly rising PH. The only chemicals I add to the pool is Muratic Acid for the PH and occationally I add bleach to get my Chlorine levels where it needs to be. Thanks for any information you can provide me.
