Any opinions on brands of Chlorine Pucks?
I usually use them in an in-line feeder to supplement BBB until CYA gets to an acceptable level. In previous years I remember reading posts about additives in certain brands. thanks
HTH (and some others now) are putting a small amount of copper in their pucks so they can call them multi-purpose or dual action. The copper really isn't enought to be algaestatic unless you use them for a very long time. Look for pucks that do NOT have additional ingredients listed on the label (unless is is only sodium tetraborate, which is borax. I have seen some puck with this added to help prevent the pH drop from acidic trichlor.)
I've had good luck with the HTH pucks and the Sam's Club brand pucks - i guess they're all about the same. You're smart to keep your eye on your CYA level. There is a tremendous amount of disagreement on how much is too much -- some folks say 30-50ppm is ideal, and that has been the conventional wisdom for some time. My pool is about 80ppm, and I've never had a problem at all. I use a chlorine puck or two in a floater at all times...just in case...but I normally add chlorine by using wal-mart ultra bleach. I just like having a puck or two floating in the pool in case I forget to check the level for a couple days and it drops too low.
Please refer to Ben's Best Guess CYA chart. The issue isn't whether your particular pool has never had a problem at 80 ppm (and what FC?), but whether ALL pools will be guaranteed to not get green algae if they maintain a certain FC at a given CYA level. That's what the chart is about. Your pool may not have nitrates or phosphates in them so you won't get algae because of that even if your FC is lower than the Min on the chart (for your CYA), but that doesn't mean that everyone's pool will be the same. In my early days (before I found this site and before I figured out some pool water chemistry), my pool got to over 100 ppm CYA with only 3 ppm of FC and didn't get algae, but I was using algaecide regularly and had the pool covered frequently.
Also, you can absolutely have rather high CYA (even close to 100 ppm) with relatively low FC (say, 3 ppm) and not get algae if you use a weekly dose of PolyQuat 60 algaecide, but that is more expensive. It does let you use Trichlor tablets in a floating or inline feeder instead of having to add chlorinating liquid or bleach every day. So there are options, but they have differing pros/cons.
There has not been one case, and I mean literally one case, of green algae in a pool following Ben's chart -- and that's with chlorine alone and no algaecide. There have been reports of the heartier mustard/yellow algae, but we figured out the higher level of chlorine needed to keep that away (essentially the Max column in Ben's Best Guess CYA chart or the 0.07 column in my chart (the 0.03 column is the minimum to prevent green algae and 0.05 is the typical column that is followed and is in between Ben's Min and Max columns).
One of these days I would love to create a tub or basin with equivalent pool water (i.e. with calcium chloride and sodium bicarbonate) and add nitrates and phosphates for a great algae bath and then see exactly how much chlorine it takes to just barely inhibit the algae (green and mustard/yellow) in their best growth conditions. That's an experiment that this industry should have done a long time ago, but never did. One guy did do an experiment, but didn't maintain FC levels and didn't ensure there was no ammonia in the algae extracted from its broth and he "proved" that CYA didn't matter (you can guess why -- the amount of monochloramine that's formed is independent of CYA and it kills algae). His study was funded by Olin Corp.
Richard
Unfortunately, that's not true. HTH is adding copper, which turns blonde hair green and stains liners, just so they can say "Dual Action!" on the label. It is an algaecide, but chlorine is more effective.
Unless you have a specific need for copper in your water (and it does happen) I would avoid Tri-Chlor pucks that are fortified with copper.
Tri-Chlor is tricky enough to use correctly--it adds CYA rapidly and drops pH rapidly as well. That doesn't mean you shouldn't use it--it just means you should watch your pH and CYA levels carefully.
Tri-Chlor is GREAT for people with new hard-surface pools that are still curing. Such pools will need CYA, and Tri-Chlor brings it up gradually enough to allow good control. Also, curing pools tend to drive pH 'WAY up--the acidity of Tri-Chlor helps control that as well.
But Tri-Chlor is sold as a full-time, all-you-ever-need chlorine solution, and it is NOT that. Only bleach/Liquid Chlorine and Salt-Water Generators qualify as that.
My original post was before the forum crash. Probably 2 years ago at Sam's Club they had two types of tri-chlor pucks. Both same weight, same concentration, same listed ingredients. No mention of copper. I know that because I was aware of the copper addition at the time so I specifically looked at the label. One bucket $10 more than the other. The more expensive was tagged as 'all purpose' or something like that. Nothing more to say than just try and be aware.
Without debating the right/wrong way to use Trichlor tablets, I would highly recommend the Leslie's store brand. They have a competitive price in store, and if you get on their mailing list, they always have a 10 or 20% off coupon that arrives around opening time.
Their Trichlor is 99%, with 1% inert - no fluf-n-stuff
I get my pucks from KMart because the the AquaChem pucks do not contain copper.
While most of us here abhor the games the chemical industry plays on pool owners, the bottom line is that every concoction has its pluses and minuses. The trick is to KNOW what those are and use the concoction appropriately.
Still, generally, simple but consistent techniques like B-B-B work best. There are times to deviate, but they are not typical.
AquaChem is one of Chemtura's companies. Chemtura is also Bioguard, Omni, Guardex, Hydrotech, Sun, and Pool Time. These are the people who feel that CYA up to 200 ppm is accetpable in a pool. I was on the phone with AquaChem yesterday about their test kit (and never got a good answer even after speaking to three different people about the hardness test) and they told me that they didn't feel that high CYA levels were a problem as long as they were under 200 PPM!
Unfortunately, this is pretty much Chemtura's corporate line across all their brands. I guess if they told the truth about CYA they would loose too much revenue on lost algaecide sales (Not to mention all the sales of expen$ive borax they sell as Optimzier (Bioguard) and Maximizer (Omni, Hydrotech, Guardex, and Sun)! They have 39 different algaecides among their brands and that's just the US market! I thought the only algaecides were either copper, linear quats, and polyquat! (Well there is also sodium bromide and inoragnic ammonia). 5 brands and 5 kinds of algaecide each would only be 25 different products. Is there a pattern here?:eek:
Edit: When I was speaking to them I mentioned Arch Chemical's (HTH and Poolife) recent study that showed CYA levels of 100 ppm or higher damaging plaster and they basically discounted it and said that their reseach has shown no problem!
well how do you keep this level below 100
mine this spring was 348 so i dumped out 1/3 water now it is 49
how do i keep it under 100 cya
Simple answer, stop using trichlor and dichlor. Both add CYA to the water. Use an unstabilized chlorine such as bleach or liquid chlorine.
Take a look at your method of testing, your numbers here don't look right.
My understanding is that levels above 150 or so are difficult to test accurately. Also, if you did have 348 ppm of CYA taking 1/3 of the water would only lower it to 232, so your original levels were likley much lower.
As stated above however, if CYA levels pose a problem for you (getting high - above about 60-80) then you should discontinue using Trichlor or Dichlor chlorinating products and resort to an unstabilized product like standard 6% ultra bleach or other economical Sodium Hypochlorite solution (i.e. liquid shock - 12.5% NaClO)
I personally use a combination of bleach when it's convenient, and trichlor tablets when it's not (or I need to raise my CYA). That keeps my CYA level below 80 every year. Over the winter I tend to have to pump out at least 7000 gallons from rain fill, that helps with lowering CYA over the winter as well.
