chem geek
			For a complete test kit that includes the FAS-DPD chlorine test for free and combined chlorine (the sum of free and combined is total chlorine), that's the Taylor K-2006 test kit. This will also test pH, Total Alkalinity (TA), Calcium Hardness (CH) and Cyanuric Acid (CYA). It also includes an acid/base demand test, though that's not particularly useful for small increments in pH.
If you only need the chlorine test kit because you have everything else, then you can get the Taylor K-1515-A which is a FAS-DPD chlorine test only (no tests for pH, TA, CH or CYA).
Richard
