First encounter with DE Filter
Hello All,
I'm so glad this site is back up just in time for pool season, I don't know what I would have done without it. I have just inherited an in-ground pool, and the filter that was left to me is a FNS Plus Vertical Grid DE 36sq ft filter. I used to have a sand filter for another pool in an old house, but I have never dealt with a DE filter before. It seems that it was cleaned last year before the pool store closed it. Any suggestions or tips on what I need to do to start it back up would be greatly appreciated. From reading other posts I've learned that it's good to mix the DE powder with some water before pouring into the skimmer. My main concern is actually how to just get the filter running. Is it as simple as just putting the lid and the clamp on, and starting it? Should I add water to the filter first? Thanks in advance for all the help..
Lost in DE land....
Re: First encounter with DE Filter
Thanks for all the help. I successfully opened the pool today. My psi on the filter is currently at 4. Is that normal, or does it seem a bit low? I've got plenty of water in the pool, the return pressure seems normal. I've already added about 7 cups of DE "slurry" to the skimmer.
7 cups of DE, as in seven 8-ounce measuring cups??? Way too little DE.
There should be a label on the filter saying how much DE to use. A 36 ft2 DE filter usually should take about 3.6 pounds of DE. An empty 'pound' coffee can will hold about 1/2 pound of DE powder, so you'd need 7 cans full of DE to get your 3.5 pounds of DE (close enough to 3.6 pounds).
As to the pressure, maybe your pressure gauge is NG and needs to be replaced. Or you don't have to valving set properly and you are starving the pump of water and hence have a very low pressure. Or you have a suction-side air leak and hence have low pressure. It could be many things, or maybe that is just the pressure that your clean filter runs at.
1. Dont guess how much DE to use. The DE box will tell you exactly how much to use. Just put that amount in a bucket. Add some water to make a slurry and dump it in the skimmer. The slurry will coat the filter. Once you do this and let it run awhile, you can shut the pump off, remove the filter cover and visually observe that the DE is coating the filter like white mud. There shouldnt be any screen visible. Its really pretty simply and fail proof. You wont screw it up.
2. I do not rely on the pressure guage on the filter to tell me when to change the DE. I have found that my filter can be totally clogged and the pressure guage doesnt move at all. (And I am an oilfield engineer and I replaced my cheap pressure guage with a high quaility industrial brass one -- its not the guage.) I have found that when my filter is new, the return line to the pool is very strong -- like a jacuzzi jet and my vacuum works great. When my vacuum doesnt pick up or the kids complain that the return jet in the pool is weak, I know its time to change the DE. I have found that changing the DE every month works very well. Some people say that you can let it go almost a season, but I like strong filtration. Its your preference.
Originally Posted by Lenny
waste, could you explain this a little further? I have 2 skimmers but close the unused one when I'd adding DE. I haven't intentionally openend any other input source when doing this.
Lenny, sorry about the delay! I actually answered you last week but my wife came in and used the computer while I was doing it ( I thought I had hit "post", but apparently hadn't - again, sorry).
With 2 suctions going, you have a plug of DE laden water comming through 1 and an equal amount of non-DE water comming through the other. This ~ equates to doing the slurry (DE mixed with water joining with plain water). I know for a fact that this evenly coats the grids, or fingers, because I've had reason to open a number of them almost as soon as the DE has been added and they have always had a good, even coating.
Thanks Waste! That makes sense.
I'm running a 36sqft DE filter also- if memory serves me correctly (and it's getting worse every day) I used 36 cups of DE to replenish my filter. Check the instructions on the bag. I wouldn't recommend mixing it with your hands - get a heavy duty yard stick or something. I also use 2 buckets and mix it half and half, that's a lot of DE to mix in one bucket and it makes it easier to dump into the skimmer, especially if you're 5'3 like I am. Stir it quick right before putting it in- it settles to the bottom of the bucket quickly. Rinse your buckets out good - and mark them for DE USE ONLY!!
ALSO- lube any O rings, my filter comes apart in half and there's one big one all the way around it.
My DE filter has been a life-saver with our iron issue here in Nebraska. The pool store lady had a fit and told me to not use a DE filter with our iron problems; when in fact that's even more reason to use one! I'm not putting down sand filters, but I keep reading posts about people using sand filters and adding DE powder to them, or Zeolite (sp?)... to get similar results of a DE filter; WHY NOT JUST GET A DE FILTER???
