Originally Posted by gldungan
Kurt,
Yes the water is perfectly clear at the start, then I add the DPD powder, shake and the water becomes pink. Then I start adding the R-0871 and the pink goes away but the water is not as clear as it was at the start. It's not really milky it's just not clear. When I add the DPD #3 reagent to the cloudy water in the comparator the color of the water remains unchanged (no hint of pink) just the same cloudy water.
My pool is very clear. One can read the writing on the main drain covers from the jumping rock.
I appreciate you input. I guess I will continue to use the powder until either someone makes a case to do otherwise or I need to order more reagents.
Gary
