SunHeater solar which is in and out?
I cannot for the life of me figure this out. I had my 2 solar panels on the ground and now put them on a fence. They are now end to end; not side by side like in all the illustrations.
So, the label ends are facing each other. I will put the "in to solar in the bottom right one, .... so now the top right is the "out to the next panel" one. Which do I connect it to on the left one? can it go in the left top which would be easier to plumb, or does it always have to go in the bottom...
I do hope someone can understand what I am doing...(obviously I don't)
Thanks,
Ellie
Re: SunHeater solar which is in and out?
I am finally getting it. I think the parallel is better. I can also then use one or two if I put a valve in.
Now, if I split the line coming in to go to both bottom "in" lines in the solar panel.. you said to combine the top. Where then would they come out and back to the pool? Now, am I going to the ends where I had them capped off?
Plan to get this done tuesday. Thanks for any help.
Ellie
Ellie,
Just to be sure it is clear, you don't want the 'hottest' water. You would get that with low flow and series panels. You want MAX HEAT transfer which would be at max flow which implies parallel hookup. Temperature is different than heat. If this concept still isn't clear, we can explain it further with some analogies but it will take some words.
Thanks, Al. I am understanding that. This is what I plan to do: let me know if it needs correction or more work.
These are on the fence making it look 40' long with a space in the middle of them for plumbing and I am putting the pipes under ground right next to the fence...then up to each panel.
From pool to solar... a "tee" to right panel into right bottom
an "elbow" and up to left panel into left bottom
From solar to pool a "tee" to right panel out of right top
an elbow to left panel out of left top
Both panel ends will be capped... the far ones.
I will put a gate valve in each line just before the elbow going to the second or left panel so that I can use either one or both panels at one time depending on the season and how much I need.
How did I do?
Ellie
Ellie,
Think you have the definitions of left and right panels reversed. The way I reworded it, the feeds are in the center space between the panels.
From pool to solar... a "tee" to LEFT panel into right bottom
an "elbow" and up to RIGHT panel into left bottom
From solar to pool a "tee" to LEFT panel out of right top
an elbow to RIGHT panel out of left top
Yes, that is it exactly. Thank you for clarifiying. Gee, unbelievable how much effort this took me. It was easier taking the cover off the 15x31 ag pool by myself yesterday!!
Thanks for the advice and patience. I will now be able to use one or two panels. I like that.
ellie
