Cloudy gone, new problems now
I felt like I had won the lottery when I found you people last week. Here is a brief synopsis of our problem:
20,000 gal fiberglass, cartridge filter with new cartridge. Water was cloudy and pool store had us adding muriatic acid by the gallon (>250, no printout) Then the green tint. Treated with very expensive algaecide and floc and nothing. Now very green. New pool store and less expensive algaecide and clarifier and after vacuuming to waste, no green, but back to cloudy. Lost faith in pool store and found YOU! Used 5, 1.4? gallons of clorox on Saturday and left the pump running. Water looks great now, but a beautiful color of blue it's never had. What does that mean? Back to pool store #1 yesterday, told them what I did and received a cool reception. They did run the water for me:
FC 7.8
TC >10
CC 2.2
pH 7.6
Hardness120
Alkalinity w/stabilizer correction 82
Cyanuric Acid 95
Now they want me increase my alkalinity (after all those gallons of muriatic acid) and increase hardness with Ca hardness increaser.
What do you wise people suggest I do? I haven't been a very quick study for the pool chemistry thing. But I'm reading old threads and learning slowly. Thanks for all the wisdom out there.
Re: Cloudy gone, new problems now
Glad it is looking better. The biggest problem I see is that high cya (stabilizer) reading. At 95, you are going to have to keep your chlorine high all the time or you are going to have a repeat of your algae problem over and over. Take a look at the following chart.
Ben's 'best guess' FC/Stabilizer table for algae free operation of OUTDOOR pools -- as of July 2003 --
Use the info in this chart to help you figure out what levels of chlorine you need to maintain in your pool based on the amount of CYA (cyanuric acid, also called stabilizer) that you have in your pool. (FC = free chlorine)
Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
=> 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
=> 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
=> 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
=> 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
=> 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
We like to suggest cya readings of 30-50. You have two options. One is to keep it at 95 and just maintain higher than normal chlorine readings. The second is to do a partial drain. If you exchange 50% of your water, that would put you at a good cya level. Your choice. Either way will work.
If you decide not to do a partial drain, then you should continue shocking your pool up to 20 or so until you get rid of that CC reading. Test at least 2 and 3x times a day is better and each time, raise your cl back up to 20. Also continue to run the filter 24/7.
Either way, your alk and calcium hardness readings are fine. Keep us posted about what you decide to do. Welcome to the forum!
That chart is what sent us to the grocery store for Clorox. But according to the "pool store", I don't want to swim in TC of 10. I assume that with the Cyanuric acid level as high as it is, if I keep chlorine as high as the chart suggests, I can still swim or you would be suggesting the drain immediately.
Also, why the wild shift in Alkalinity in a two week period? I only got a C in college chem, but the husband is a chem major. He'll understand the explanation. Thanks for your help. What did people do before the internet?
With a cya of 95, it doesn't hurt to swim in cl of 10. I wouldn't swim with cl at shock level however. Are you going to just run high cya and high cl or do a partial drain? Not sure why the swing in alk.
It's not clear to me if you're still trying to get your water crystal clear. I think you are but please post back and confirm that before we reccommend a plan.
This is the real deal. Maybe. The pool is very blue, a color I'm not familiar with. My inclination is to tell you it's not cloudy any longer, but the blue color really is throwing me for a loop. The fiberglass is not blue, but white. (And now appears to have stains, but that's another thread for another day) So let's assume it's clear.
I am now the proud owner of a 5-way WalMart test kit. These are my results as of 10 minutes ago.
CL-Orange
Ph-7.5
Alkalinity-after 60 drops changed only to a champagne color
Cyanuric-below the mark. Maybe 3/4 inch of solution covered the dot
Hardness-indicator turned water pale, pale, barely there champagne
Not very similar to the pool store results of yesterday. How many square yards of dirt does it take to fill in a 20,000 gal pool?
Iskeate,
99.0295 cu. yds of dirt will fill a 20,000 gallon pool....about 7-8 dump truck loads. However, don't call them just yet!:D
I'm gonna recommend you shock your pool pretty hard. Since it's FG, I'd like to see you bring it up to 30ppm. To do that you'll need to know where you are now so, unless you get an accurate result (not "orange"), let the Cl drift on down 'til it looks like about 5ppm (might take a day or two)....then add 25ppm more to get to 30 (8.3 gallons)
I'm not familiar with the testing method for that kit but your pH is fine so I would disregard the Alk and CH for now, at least.
I believe that's all you need to get the water to crystal clear blue. Run your pump 24/7 the entire time...that'll help your water clarity, too.
Others will be along to help you interpret your Alk results...it's an easy fix, if necessary....so is the hardness if it needs it.
You would do well to disregard the pool store's advice....what they recommended doesn't make sense.
Where do I get an accurate reading? The HTH kit doesn't go that high and the local pool store says their machine doesn't read past 10. Our previous shocking episode was based on info received at this site. If your cya is X then Y gallons of bleach will bring it up tp Z. It was truly a guess. And to complicate matters, we are leaving town on Friday at noon not to return until Wednesday afternoon. Gracias.
Now I noticed that you had a CC of 2.2. That means you are STILL fighting something so hammering your pool up to a FC of 30 is a pretty good idea (I assume F/G can handle that).
Your other numbers are generally OK. Alk is a tad low, CYA is high, but both are handle-able. Get everything else straight first.
That's what I understand CC to mean also. Yesterday, when I asked the pool store girl if CC meant "the chlorine was currently working and still killing something then becoming unavailable to kill again" she told me no, that's not what it means. She couldn't explain to me why I wanted such a low or nonexistent CC level. One of us needs retraining.
But I still don't know how to increase the cl to a for-sure level of 30. Aside from the method I mentioned earlier, which is a best-guess scenario, how do I measure that high?
Accurate tests for Cl can be obtained with Ben's kit (the best) or a Taylor 2006 kit (orderable online) Ben's kit will get you speaking the same language as all of us and is well worth the wait.
You can get a reasonable idea of your Cl level by diluting your test water with distilled water. So, if you dilute by 50% and get a reading of 5ppm, your "real" reading is 10ppm. It's not very accurate and it's a "stop gap" method but you'll get close enough for this purpose.
You are slightly misinterpreting the "best guess" chart. The CYA does not affect the total Cl....the Cl is simply less effective at high CYA levels. That's why I'm suggesting 30ppm of Cl.
Since you're leaving town, get the 8 gallons of Cl in there tonight and get the process started. I have a feeling your water will clear before you leave. See if you can get a neighbor to put in small jug of Clorox each evening and run your pump for 8-12 hours each day....that'll protect your pool while you're gone.
You kinda mis-understood. CC is Combined Chloramines. It's metabolized something and now won't sanitize. It smells like chlorine (!), irritates skin and eyes, and gives chlorine a bad name. You shock to not only kill stuff, but to break the CC down again, leaving your pool sweet-smelling and non-irritating (and, of course, clean!)
Before we left town, we added the 7 gallons of bleach, and set the pool to filter 12 hours a day. Came home last night and it looks beautiful. Took water to the pool store and these are the numbers:
FC - >10
TC - >10
CC - 0.0
pH 7.8
Hardness 180
Alkalinity (w/stab correction) 122
Cyanuric acid 95
Pool girl told me the combined chlorine number is insignificant because their equipment will only measure to 10? So I came home, diluted with distilled water and wild guess has it at about 15. I'm willing to order Ben's test kit but I can't get a feel for how long it will take to receive it. I realize our stabilizer level is high, but it's been a week and the chlorine levels just creep down. What's the reason?
Also, for now I want to deal with higher chlorine counts as opposed to doing a partial drain, unless you wise people advise otherwise. Should I be doing anything now besides enjoying the water? Thanks for your help.
It took me about 2 weeks to get my testing kit - realize it must go all ground due to the chemicals in it.
pH is a bit high--I'd lower it to 7.3-7.5.
So is CC TRULY 0 or is the pool store idiot saying that? If it is you are in good shape. If both FC and TC are the same that's true because TC = FC + CC. That's always and forever.
Pool girl said it was not a significant number because they can't test Free or Combined Cl over 10. Please help me understand why I want to lower my Ph?
The higher the PH the less effective the chlorine - plus you are on the higher end of normal. Acid will lower the PH - download the bleach calculator to determine how much to put in.
FC - >10
TC - >10
CC - 0.0
pH 7.8
Hardness 180
Cyanuric acid 95
Hey I ordered Ben's kit on Monday and it is scheduled for delivery tomorrow!
I've had the same blue cloudy water, except I have a little mustard algea problem. Bleach, bleach, bleach, acid, borax, baking soda, etc.. It's all starting to work. Hang in there-these guys are good. Oh yeah I also added Yellow treat for the algea..... Good luck!
