I have a inground vinyl 20X40 pool all of my test are within range BUTeach day I come home and algae is appearing again. I scrub the walls and floors and then vacumn on waster after everything settles. The next day same thing it slowly appears. Also I notice when I added boric acid 20 mules in the beginning it seems that the water cleared but once someone starts swimming the water is no longer clear. I turned off my pump during the day and run it from 6p to 7a each day. What am I doing wrong. Also super shock is that not the same as bleach. thanks for any help in advance.
