We have a 23,500 gal in ground vinyl pool, Chlorine
WOW...its been two weeks now and I still don't have it fixed. I left the pump on low while we were gone for a week and it was a mess when we returned...cloudy, yellowish, couldn't see bottom in 8' end, chlorine dropped to 0. We got a good bit of rain and I guess the water was pretty warm too. Anyway....After shocking it was still quite a mess. Chlorine level is good now, but I am fighting with the PH and Alkalinity. The alkalinity was at 200...after aerating with the jets for 2 weeks it is down to 150. During that 2 weeks I added 32 oz of algae treatment because it looks like there might be algae in the water, though there is none on the walls. The PH was up so I have gradually been adding acid to bring it down. It was 7.8 today and I added about a pint of acid. I will check it again in a while. All that being said....I have a PH of 7.8 and Alkalinity of 150. I can see the bottom, but it is still cloudy and the color is not pretty blue like it should be. Any help appreciated.
