My 33' pool is 1/2 way full and the electric should be hooked up in a couple of hours. I have gotten in a couple of times, although I haven't added any chemicals yet. I tested the water and here is what I have at present. (Wallmart test kit) Also, I noticed a slimmy feeling on the bottom and a slight stinky smell.
ph-bellow 6.8 (which is as low as my test reads)
alk-2x10=20
hardness or Cal. Carb-2x50=100ppm
Should I put some try clore tabs in a stocking close to where I'm running my hose in the pool?
My electic will be on shortly but the water is still quite low. Can I run the pump with the automatic vacume to get the water filtered a little bit. Thanks for any help. Sharon
