New user looking for help with scale
We put our pool in and started it up in the spring of 2005. It is a Hydraazo finish 18 x 36 at 9 feet at the deepest end. We figure it is about 27,000 gallons and we set up from the beginning with a Salt Water Generator.
Thus far it has been a great pool that has suddenly experienced a significant amount of scaling - hoping to find some assistance here.
Re: New user looking for help with scale
Post a complete set of current water testing results taken with a drops-based kit. The kit we recommend is the Taylor K2006 or 2006C (better buy). Not available locally; you can get it here: http://pool9.net/tk/ (Until your registration is complete, you'll have to log out first to be able to see the rest of the forum, so copy that link and paste it in a browser window after you log out.)
In the meantime, you can pick up a HTH 6-Way kit at Walmart (not the 6-Way test strips) and use that to check your readings.
Welcome to the Pool Forum!
I researched this topic quite a bit and have already started taking steps to get the calcium scaling under control, but I am treading into territory where I have no experience and am not altogether confident that I am doing the right thing.
I have a Taylor K-2005 Test kit, I see you recommend the K-2006 which I can get when I need more reagents -
I balanced the pool chemicals in Sept when we shut it down, pH was 7.4 and everything looked good. When I opened up the pool cover to check on it in March - I got the following readings:
pH 8.0 (as high as the scale goes) It took 4 drops of reagent # 5 to get it down to 7.6
FC 0
TA 100
CH 180
CYA 0
Temp 42F
I also measured phosphates and they were through the roof - (above 1000 ppm), Salt 3000
I noted way more scale than when we had closed it over 80% of the surfaces are affected, the steps were rough like 36 grit and at that time I scraped some off and it bubbled furiously in vinegar and also in muratic acid. The crystals look clear when in the water and white when out of the water.
I added acid and then decided to set the pump to run 6 hours a day and checked it weekly through the month of March - I kept the pH between 7.4 and 7.8 by adding acid regularly (went through 4 gallons of acid in March)
The scale was not improving so I decided to pull the pH down to 7.2 and keep it there as best I could, I added 64 oz of Purple Stuff and this seemed to help over the next two weeks. The scale was still very hard, but it did come off of all the tile and it became smooth. The scale stubbornly clung to the hydraazo.
I called Jacks and they suggested Solution #2 and directed me to some instructions - I waited a while to see if I could get things to improve without spending the money on this solution - but with no improvement by the end of April - I ordered 4 qrts of purple stuff and enough solution #2 to dose the pool.
I put the Solution #2 in according to the instructions 1 week ago. I have seen no additional improvement yet.
I have been keeping tabs on the pool, today's readings are:
(I started using chlorine tablets as I re-plumbed the heater and salt cell out of the circuit before dosing with Solution #2)
FC 1
pH < 7.0 according to the Taylor test, it is <6.8 according to the test strips I bought
TA 40
CH 250
CYA 0
Temp 72F
Phosphates still > 1000 ppm and Salt 2700
So far, the most effective means for getting the scale off is to use a left over tool tile and just scrape it off. I was hoping that it would go back into solution with a little less work . . . perhaps I am being too impatient?
Has anyone else used this treatment with this kind of scale and gotten good results?
Please look at the 'sand algae' page, and see if this is what you have experienced: http://pool9.net/algae-s/
. . . membership upgraded.
Yikes - that is much worse than what we are experiencing. We don't have any green, no slime and the water is clear. I'll try to get a decent photo and post.
The algae deposits the calcium; the pictures showing the white sand-like particles are what remains after the algae is gone.
Here are a few photos that I could take in the shade -
https://lh3.googleusercontent.com/-u...-15-13_660.jpg
https://lh4.googleusercontent.com/-h...-16-39_660.jpg
And this one with a lot of reflection - The top step I scraped and then brushed with a Scotchbrite pad and it is pretty good now.
https://lh3.googleusercontent.com/-5...-14-33_221.jpg
When I first started opened the pool, the tiles also had crystals on them, but they are for the most part clean and smooth now. But the crystals on the Hydraazo pool finish have stopped shrinking and are very hard. You can scrape them off with a pool tile but it is a lot of work.
The pool finish is supposed to be dark in color (maui midnight). With the scale, much of it has turned to a light gray color.
Based on the 'fizzy' test (bubbles when in vinegar or acid), you can probably remove those . . . but SLO-O-OWLY. If you want to remove them rapidly, you'll need to drain and acid wash. I don't recommend that, because acid washing damages the finish.
To remove them in place, you need to lower the alkalinity to 60 ppm or so, and hold it there, till the scale is gone. You'll probably loose a bit of your finish, too, but not nearly as much as you would if you acid washed. To lower your alkalinity, read this page: http://pool9.net/alk-step/
Thanks for the link. I have a chlorination canister that is not used that has two small tubes linked to the plumbing. I can connect a small air pump to the return line tube and get a nice flume of bubbles out of the water inlets to bring to total alkalinity down.
I am one week in on the "Jacks Solution #2" process, I'll let it Run one more week and then bring the pool back into balance.
Any specific pH target I should aim for in this effort?
As Yoda said, "Do or do not".
As we say: "Pick one, us or them"
We're not familiar with -- and do not support (or reject) -- Jacks Magic processes. But, it never works out to 'mix and match' chemistry approaches. So . . . when you're done with Jacks Magic stuff, repost if you still need to do so.
Best wishes for your success!
A quick update on this thread - I have started to pull the pH back up. The base demand test showed 8 drops to get the pool to a pH of 7.0
I did a bucket test and figured out how many teaspoons were in a pound of Borax and am going to the store to buy 20 lbs to start with. I also measured the pH of the water coming out of our well - yikes! Very high calcium hardness and pH above 8.0 - I might do an acid demand test on the well water to see if this has been the ongoing reason for our need to add acid all the time and now also dealing with calcium scale.
Lastly, I started aerating a few days ago. I have an oilless compressor and connected it to the return line through the Chlorine canister plumbing at about 5 psi on the regulator. Gives a nice plume of bubbles out of the two most shallow water inlets.
https://lh5.googleusercontent.com/-F...-10-52_182.jpg
I replumbed temporarily to take the heater out of the circuit while doing the Solution #2 treatment.
The Jack's Solution #2 acid bath removed about 50% of the scale and what is left is quite a bit easier to remove now by scraping with a plastic dish scraper. I can tell that it also affected the Hydraazo finish - when you rub it with your hand, it feels slightly slimy and you can see a light dark cloudiness in the water around the area you rub so I think that is the pool surface being attacked along with the scale.
We are having our son's senior graduating class (only about 20 kids) over for a senior night pool party next week so time to bring this back into balance and get it ready for summer use. I'll keep the Alkalinity low as suggested and work to keep the pH in the 7.2 range and see of the scale disappears the rest of the way on it's own.
motion guru
Sounds prudent.
Actually, if your calcium is still under 300 ppm once the scale is gone, controlling the TA level is probably all you need to do.
Just don't let the pool go out of control this coming winter. ;)
