Hi gang! I just discovered the BBB method a little over a week ago. I had mostly ignored my pool over the winter to save on chemicals and all the hard work of the pool store method. As soon as the weather warmed up a bit - BAM! Green Pool! After a nine day battle, and about 25 or so jugs of bleach, and 14 cleanings of my filter cartridges, pool is mostly clear of algae. So my opening question is, how quickly do I allow the chlorine level to drop from shock level to maintenance level? It's now clear enough to see the bottom, and color has changed from green to aqua blue, but it's still a bit cloudy.
As soon as I have access to my profile, I will add a signature with all my pool details. Not sure how much you need to answer this question, but my pool is inground, gunite, and about 12,300 gallons as best as I can estimate.
Thanks!
