Re: Bleach Calc - New Feature Request
Hey Michael,
Is there any way to add a feature that would calculate the amount of CYA being added via the trichlor pucks? I just refilled my pool, I know how much CYA I've added, and I know how many pucks I've used so far. If I knew how much CYA each puck is adding, I could then use the dilution calculator to determine how much water change I need to do to dilute the CYA. This by-passes the need for the clunky turbidity test for CYA.
Could you get to that, by, um, Friday? :p
Tom
Originally Posted by aquarium
Hey Michael,
Well, there's a lot of confounding factors that will throw your accuracy off with calculating how much CYA you've got in the pool. That's why testing is the best way of determinining how much you've got in there. Over time, due to drag out, splash out and pump out, your calculated number will diverge from the actual. It may be good for a short while, but eventually it will get off. Actual testing is really the best way to go about this.
Michael
That seems to be the million dollar question.
I've looked and looked and looked, to no avail... :(
