What level do you run your CYA at, and why?
well over 100, but not because I want too. Pool builder sold me a chlroine tablet tower during sales pitch. At that time I didn't know better, and still using tablets. I just hate to waste them. Will be draining the pool some this weekend to lower CYA. Moving to SWG hopefully this winter.
I run about 35 PPM CYA. It is enough to keep the chlorine from being burned off too much by the sun, but minimizes the negative side effects. Keeping it low leaves a little headroom in case the SWG fails right when we're going on vacation. The low CYA would allow us to run a tri-chlor floater for a while, if necessary, without driving us to have to do 25 PPM shock treatments.
i run 0 cya, because when i tried to run a cya of 30-40 it was too much trouble because every 1-2 weeks i need to add 1-2" of water loss due to evaporation and also because of rain the cya was always low and i was constantly adding cya powder to bring it back up which was costing too much money. so instead i just add 2.5gallons of 10% bleach per week, half on monday other half on thurs or friday and float a 3" tablet 1 per week. this system works well for me.
-Arron
I like to start off with a cya of 30, then I use bleach and pucks during the summer. Starting off with 30 leaves me room to use the pucks for whey I am away and when I need them for stains. I also throw one in when my ph gets high, those pucks sure bring the ph down quick.
I keep mine at 80-90. I live in a HOT climate, my pool is full sun all day, and I have a large swimmer load on a daily basis. If I try to keep mine lower, there's no way to keep up with the chlorine demand without taking a chance on an algae bloom.
I like to start out around 30ppm or less as well. This leaves me room to use the inline feeder with pucks supplemented by bleach until I reach 50. I then go straight to bleach.
David
try and keep mine between 60 and 80 ppm because that is what the manufacturer of my SWG recommends and a call to their tech support line told me that it is recommended at that high a level with a SWG because of the 'superchlorination' that takes place in the cell whenever it is generating chlorine. Don't know how true it is but I do know that when the levels are in that range the pool water sparkles and my FC levels stay pretty constant. I have a leak which the builder has yet to fix and my cya dropped to maybe 20 over a 3 month period and I started having all kinds of problems holding chlorine in the pool once the cya got below about 40 ppm!
Originally Posted by mbar
This is my regimen exactly :)Quote:
Originally Posted by DavidD
Ditto. I pull a bucket of pool water, set the Cl level with bleach, and test it during the day. On a moderately high UV day (8), I use 3.5ppm Cl at 80ppm CYA. I then calculate what cell output level is needed for various run times to generate that amount of Cl.Quote:
Originally Posted by aylad
Running at 30 now. Save the pucks for going away. Try to keep below 50.
Same here....Quote:
Originally Posted by Bleach=Chlorine?
Thanks for all the responses :)
Janet, Please correct me if I'm wrong.Quote:
I was under the impression that while stabilizer keeps chlorine in the pool, it prevents some of it from doing it's job and therefore more is needed to do the same sanitizing job as lower amounts in a low/no stabilizer pool.
For example, imagine after a party, 3 busboys (FC) start cleaning up. 2 drunken women wander back in (stabilizer) and grab two of the busboys and start dancing. There's still 3 busboys in the room, but only one is doing an work. Manager (pool owner) quickly sends 2 more busboys in to do the work, now there's 5 busboys in the room, but only the 3 are doing any work, the same as was getting done without the drunks.
If this is how it works, why is CYA even needed at all?
In the past before finding this forum, I like others ran a sky high CYA because the pool store wanted it that way. Now I know why... :(
I used bleach about 1/2 of last season, and closed it with bleach. This spring my CYA is low, about 20ish, and I'm maintaining FC between 3-5 ppm, and so far so good.
I think one of the "chemistry buffs" can explain this more technically that I can, but my understanding is that the CYA doesn't "tie-up" the free chlorine - if it did then it would change to combined chlorine (which is bad).
The CYA does inhibit the FC to do its job as well - so to add to your analogy- it would be two drunk women talking to the bus boy while he is cleaning - making him slower but able to stay around come AM - while the bus boy with out the drunk women (CYA) around would die like a vampire come first light. :p
If you have some CYA then you still have some chlorine working when it is sunny.
You gotta love it!:DQuote:
Originally Posted by Rangeball
The reason you need the drunken woman is because a busboy wouldn't be fun if life was all work and no play. As each busboy stop dancing he's happy and ready to work again. The drunken woman can then take a break, have another drink, and dance with the next busboy.
If there were no women the busbuys would work themselves to death. !
:D :D :D :D
It is true that you must maintain more chlorine residual with a higher CYA--in your example, you start out with more busboys so that the drunken women tie up a smaller percentage of your help. :)Quote:
But the higher CYA also keeps the sun from consuming as much chlorine, which is needed in my case-- in straight sun for 100% of the day in daily temps ranging from 80-110, if the busboys have no shade, then there's nobody alive when the drunken women come around!
But if the drunken woman allow them to be counted but keep them from their work, what's the point?
The cya DOES tie up some of the FC and covert it to a class of 'combined chlorine' called chloramides which are stronger oxidizers and sanitizers than chloramines but not as strong as hypochlorous acid (FC). In the past sometimes anhydrous ammonia was used to help stabilize chlorine in pools by forming monochloramine, which is an effective sanitizer (Some mustard algae treatments today still depend on this chemisty).Quote:
Originally Posted by Simmons99
www.usace.army.mil/publications/armytm/tm5-662/chap6.pdf has some interesting info on stabilization of chlorine.
(Chloramides are just a type of combined chlorine that will still test as FC with a test kit and still has some sanitizing ability but at a lower rate.) However, this form of combined chlorine is resistant to UV. At least this is how I understand it. Cyanuric acid is an ammonia/nitorgen compound with a ring structure .It is in a group of chemicals called triazines. (Does anyone recognize that from the full chemical name of trichlor or dichlor?;)) I am trying to find more info on the chemisty of this right now and can only find bits and pieces here and there.
I run 40 or so just because the group recommends 30-50. Interestingly, right now I am at 10, maybe, and seem to retain the cl the same as I was last year at 40. Same amount of sun but the heat is less. Is it the heat that leaches out the cl or the direct sun rays? I'm not going to add any Cya for a while to see what happens...
I am at 30-40 right now. I try to keep a puck a week in the floater to balance my ph which creeps up up up. I actually like the ph pretty high because the water feels better to me that way. However, I'm being much more careful this year because we are taking off for 10 days at the end of June so I need a margin for the CYA to rise with the pucks I will float while we are gone. Usually, with rain and backwashing I finish the season with CYA of about 50-60 and I have a very manageable bleach consumption the whole summer. I guess I am spending about $5 a week on chemicals on the average.
