I have a well with a water softener so I will get water trucked in initially to fill my pool but then will be using the softened water whenever more water is needed. I haven't seen hardness discussed much but I just pre-ordered the PS234 test kit and I see that calcium hardness is tested. Is there another chemical beyond the 3-Bs that I'm going to need to control hardness? Thanks. Peter
