Liner slipping
Hey -
I'm in the process of installing my 15x30 AGP.
I started to slowly fill it with water from a hose, had about 8" and the liner popped out on one end.
THe instructions say to put the seam of the liner on the cove. It does not say how much liner to overlap over the side. It's not a jhook liner.
The pool place said they typically put the same of the liner up the wall alittle bit and overlap the liner about 6 inches on a hot day so it'll stretch lots.
I'm guessing they know what they are doing, but why would this happen? The liner is held on by these long U shaped clips, then the top plate.
Any insight is appreciated.
THanks,
Brad
Re: Liner slipping
Ted knows liners; I asked him to look.
Re: Liner slipping
As long as the overlap was ~ equal all the way around the pool, all is fine! :D
If the liner will no longer go over the wall and be held in by the retaining piece, there is a problem and you need to stop filling the pool.
Please don't worry about an even overlap outside the pool - what's most important is that the liner inside the pool is wrinkle free.
Please let us know how it all works out - I'm hoping that you'll be swimming tonight :cool:
Re: Liner slipping
I'm not sure I follow.
I was filling the pool, and the liner 'slipped' off on one side. Once it did that, I could no longer pull it back over. I stopped filling the pool and drained it this morning.
You can see my photo's here:
http://www.poolforum.com/pf2/showthr...all&highlight=
Basically the liner slipped off to the right of the ladder in this picture:
http://farm9.staticflickr.com/8426/7...aa78ed07ae.jpg
The liner is wrinkle free, on the floor for sure.
In the same picture, you can see some wrinkles in the wall sections. Is that what you mean?
The overlap wasn't equal all the way around. One end I had about 6" let's say, on the other I had about 2".
So I guess I should make it 6 and fill it when it's sunny?
Thanks for the reply!
Brad
Re: Liner slipping
Feel free to post a full set of photos, as you go. It will help others, later.
Neat application of the folding ladder . . . I've got one, but that never application never occurred to me. (I've never installed a metal wall type AG pool.)
Re: Liner slipping
Yeah, the ladder worked well, especially because the depth of the pool was lower then the ground, so it worked well.
So now my liner is consistently 6" overlapped around the pool. I put about 2-3" of water in and will start putting more in tomorrow once it's sunny.
http://farm8.staticflickr.com/7137/7...67a866d0e3.jpg
Re: Liner slipping
So it's sunny out and the pool has been filling for about 3-4 hrs. It's about 8" now.
The liner has slipped in one spot, about 1/4". So far so good. Note the pencil line vs the liner.
You can hear the liner actually stretching.
http://farm8.staticflickr.com/7261/7...a006231778.jpg
Re: Liner slipping
Now it's slipping, a lot!!
Notice the pencil line near the psot, it's slipped quite a bit and only has about 1 maybe 2" of overlap. This is on the one end
http://farm8.staticflickr.com/7106/7...40084c06e4.jpg
Same corner, but from the inside of the pool. Notice the pattern difference.
http://farm9.staticflickr.com/8307/7...863843b79f.jpg
The sides seem to be OK:
http://farm9.staticflickr.com/8283/7...e7142647af.jpg
What's odd, is the liner is right up against the wall on the sides, but on the ends it's like 1" away from the wall.
Does it make sense that either:
a) the pool is somehow incorrectly setup making the liner not fit on the ends
b) I didn't overlap enough
c) I dunno? haha
I don't think if I continue to fill it it'll hold. Maybe I should only fill when it's sunny, I dunno. I'm at a loss. If this slips off again,...
Re: Liner slipping
I think I found the problem...we started with the seam that goes in the cove about 6" above the cove, now it seems to have stretched/slipped to be on the floor. I've stopped the water, I'm guessing it shouldn't slip anymore, but not really sure if I should pull the water out and start over or not. I have about 8" of water in the pool
Re: Liner slipping
Well, I thought about it for a bit last night, and figured I'd start filling it again. If the liner popped out, it was going to anyways and this would give me a head start on draining it haha.
So I filled it from about 8PM till 11:30. The pool is up to 11". I couldn't get myself to let it run all night unsupervised. I started it again at about 6:30, and will watch it every so often to see how it's doing.
Now the water is climbing up the walls, pushing the liner directly against the wall on the ends. This I think is a good thing, hopefully, causing the liner to stretch on the sides. Perhaps it's now a difference force being applied against the liner (outwards against the wall, instead of down against the floor).
I have about 1" overlap left in some areas, very small. We will see!
Re: Liner slipping
Well it's going on still, up to 18" now, and looks to be stabilized. If anything, the pressure on the liner is reducing as the water is pushing it up against the wall. Going to continue filling it all day and keep checking on it!
Re: Liner slipping
Thanks for the updates and the pics!
Oval pools are harder to 'overlap' than round. With an oval, you need to be sure it's sitting ~ perfectly centered along the long wall axis - otherwise one side will slip more than the other.
The slip from pushing the liner to the wall is less tan pulling it down to reach the floor and cove. However, as you've noticed, the 'tile line' will warp. No one but you will notice the warping, as long as the liner stays overlapped, I'd let it be.
I didn't fully realize how the liner was secured before I saw the pics otherwise, I'd have suggested a different way to secure an overlap liner while it's filling.
I'm hoping that you get the pool filled with no more issues and can soon start enjoying it!
Re: Liner slipping
So how would you have secured it, incase I need to do this again (hopefully not!!)
I've seen binder clips, overlapping the liner under the top plates...
Re: Liner slipping
Ted, what would you recommend as the best method to secure the liner during the fill process? I have used clothespins before and found them fairly convenient but if there's a better way, I'd definitely be interested. The more knowledge the better for future reference.
Re: Liner slipping
Jw, you got it - wooden clothespins ;)
I use the ones with a spring, only because I've never tried the one piece kind. I fear that the plastic clothespins might tear the liner. Also, with the spring type, you don't have a pinch point.
The problem with using the toprail is graphically shown in one of the pictures above - it popped off and ended up in the pool, if a corner had landed first, it could have torn the liner.
Re: Liner slipping
Just to close the loop, liner is good, pool is full :)
Final product:
http://farm9.staticflickr.com/8295/7...35fc2bdcbc.jpg
Re: Liner slipping
