Re: Something has gone wrong
You can drain and start over if you want to, but you need to look at the cost of water and see if that's really feasible--I wouldn't drain, I'd just fix the water you have. However, your stabilizer levels are really high , so unless you want to run a high CYA-high chlorine pool (I do--and find it much easier!) you will need to drain and refill some of the water in order to lower your stabilizer (CYA) levels. Do you have metals in the water? If so, that needs to figure into your decision as well.
First off--do not use the super algae guard, unless the ingredient is 60% polyquat. Most algaecides will make your problems worse, not better. If you have algae, the fix is chlorine, and lots of it.
Second--I assume the "Pool Brands Quick dissolving shock" is dichlor? If so, stop using that, because your CYA levels are already high enough that you have to maintain 8-15 ppm of chlorine at all times to keep the algae away. I wouldn't use cal-hypo either, because your calcium is already getting high, so that pretty much leaves bleach (or liquid chlorine if your state sells it) to use for chlorination.
Since your chlorine has been way too low, I suspect that algae is the problem. You can verify this by testing for chlorine at night and again in the morning, to see if you're losing any chlorine overnight. At any rate, the answer is to add chlorine, and lots of it. With a CYA over 100, this means taking your chlorine level up to 25 ppm and holding it there until the pool clears up, and until you're no longer losing chlorine overnight. At that point you can let the chlorine come back down, but with your CYA that high, you can't ever let it come down below 8 ppm.
If you'll fill in this short chart with info about your pool, it will help us advise you better...
Pool Chart Entry Form
Welcome to the forum!
I filled out a pool chart when I registered. Did it not save? if not is there something I need to do to make it save? I will fill it out again.
Checked the Chlorine level again this morning and it is still as high as it was yesterday..
Clor 5-10
PH 7.2
Hardness 230
Alk 130
Water is still to cloudy to check for CYA...
We have been alternating using bleach and the Shock to keep the CYA level in check.
aylad
I don't see your results in the pool chart, so maybe it didn't save. When you get a chance, could you please fill it out again?
I have tried 4 times but here are the answers
Own the pool
Oklahoma
race9899
All 4 of your entries were in the data table -- I deleted 3 of them. It's possible Janet was looking at a slightly out of date back up copy of the Pool Chart data.
In any case, the information is now in your signature.
I let the pool settle, vacuumed bottom with pump not putting water back into pool, add 6 cups of bleach, pool is still green but much lighter and cloudy.
Should I have the water tested at a pool supply?
If you have green, you need to increase your every evening bleach dose to 1/2 gallon of PLAIN 6% bleach -- that's about 15 ppm on your pool
AND . . . you need to retest your pool BEFORE you add the bleach, but be SURE to test and report the CYA level. That's critical. If you want to understand why, read the Best Guess page linked in my blue signature block.
Pool is finally not green but cloudy.
Had water tested...
Total Chlorine 8.2
Free Chlorine 7.6
PH 7.6
Total Alkalinity 90
Calcium Hardness 145
CYA 151
I should add more bleach?.. We added 10% volume of water after these test's..
Are those results from your HTH kit or from a pool store? If your CYA truly is that high, your shock level will be 25ppm. (See the Best Guess Chlorine Chart in Ben's signature above for info about the correlation between CYA and chlorine levels.)
That was from the the pool store..
We have been adding over a quart of bleach per night
race9899
You have the 6-way, right? You need to test it yourself! Unless you make a mistake, it will be more accurate than the pool dealer.
