Pump Ran Dry Now Motor Won't Start
Hi, I'm new to the forum and looking forward to learning more about taking care of my pool and equipment here.
I was away for a few days and when I returned the water level in the pump was below the intake line and the breaker for the pump motor was tripped. I didn't notice that until I flipped the red lever on the timer to start the pump and nothing. A family member used the pool while I was away and made adjustments to some valves, possibly reducing the intake flow too much for the pump to catch prime when the timer kicked on automatically the next day.
I reset the breaker and hit the switch again and heard a loud hum but the pump didn't start and after a few seconds the breaker tripped again. So I did some online research and pulled the motor to check the start capacitor which was clearly blown as it had leaked plastic goo out of its guts. I checked the motor and it seemed to spin ok although there is some bearing noise. I removed the diffuser and found some thin plastic debis between it and the impeller which must have been caused by the heat of the pump running dry.
At any rate, I cleaned up the plastic residue and replaced the capacitor but the same problem persists. Loud hum and motor won't start. With power applied (if I'm quick) I can start the motor spinning by hand and it will catch and run but it will not start on it's own after being shut off.
So here's my question: What specific parts are damaged when a pump runs dry until it "seizes" or stops spinning due to heat build up. Is it possible that even though I can spin and start the motor by hand the internal shaft seals are heat damaged and causing enough excess friction (or sticktion) that the motor starter capacitor can't overcome it? Even though I can start the motor by hand? Any suggestions for further troubleshooting and suspect parts identification would be sincerely appreciated.
Motor is a 2 HP Hayward Superpump, Pump is Hayward SP2615X20. Put into service in July 2007.
Thanks!
Randy
Re: Pump Ran Dry Now Motor Won't Start
I'll ask Mark or Al to take a look.
Thanks, I may have answered my own question by digging a little deeper into the assembly.
It appears that the shaft seals failed and water got through them and into the shaft bearing near the wet end. Not sure what other damage may be present or if I can just have the bearings replaced and get new shaft seals and O-rings. Biggest problem is time without the pool filtering/generating chlorine and what the consequences of that will be...
Did you replace the seal? That can cause extra friction and prevent the motor from starting. Also, there should be no bearings noise either so if you feel or hear anything, that could be causing extra load on the motor so it won't start.
Thanks for the reply but it looks to be to far gone. I took the whole thing apart and the front bearing is shot. There's a lot of rust and corrosion at the front end. It looks like the pump must have been leaking into the motor for some time based on the amount of corrosion. Looks like I'm into a new unit.
That happened to me at the end of last year, but I was able to just replace the motor and seals but keep the rest of the pump.. Saved me about $350 that way, if it would work for you...
Exactly what I did. Retail store of the builder I used was very fair with the pricing. I bought a new motor, seals, gaskets & impeller (just in case) and cleaned up all of the other parts thoroughly before reassembly. Fired right up and sounds sweet, much better than the old motor before the failure. I put a gallon of shock in the pool and ran the pump overnight so the SWCG could replenish the chlorine that was essentially gone after four days of no operation. Free chlorine levels came right up and the chemistry looks good across the board.
Other than a couple of green algae spots on the liner (which will scrub out), it doesn't seem any worse for the wear. Only my wallet was damaged in the process but a valuable (and expensive) lesson was learned as well. That being, if you let someone use you pool while you're away, even if it is a family member or someone you really trust, don't let them touch anything. No valves, no timers, no adjustments, nothing. Leave it as you found it or don't use it at all.
Yep, that's a valuable lesson. Here's the other end of that one...if you see a leak around the pump, even a very small one, don't ignore it--go ahead and change out that shaft seal. Ignoring it will eventually produce the same result that you had.....ask me how I know! :)
Glad you got it up and running again. Funny how that stuff always happens when it's hot outside, huh?
True enough!
Although I can't say that I ever noticed any leaking around the pump at all. The majority of the corrosion was behind the motor mounting plate where it attaches to the front of the motor. Also under the front of the motor where the air cooling slots are located. But none of that was visible until taking everything apart.
I did notice some bearing noise in the motor this season and had planned to pull it (the motor) to have the bearings replaced after closing the pool in the fall. The bearing noise was noticeable but not horrible and I'm sure it would have made it to the end of the season (mid-September for me) had the seal failure not occurred. I may still rebuild the old motor and either keep it as an emergency back-up or see if I can sell it on E-bay. I can tell you that going forward I will be much more attentive to the sound of the pump motor and I'll be on the lookout for any signs of leaks or corrosion.
In the meantime, thanks for the help and the words of encouragement. It's nice to know I'm not alone out here!
RandyM1911
You may want to check during a rainstorm, to make sure something is not causing water to splash up into the motor.
Thanks PoolDoc.
I was thinking about building a little "doghouse" style roof over the pump / motor to mitigate that possibility. I have been wondering how the motor came to have so much corrosion in just 5 years of service and can only imagine that some combination of premature shaft-seal failure or leakage and possibly heavy rain / flooding of the motor vents contributed. I will keep an eye out so I (hopefully) don't have to go through this again in another 5 years!
Randy
I have a similar problem (pump motor gets regularly drenched in the rain). Mine is on a pad but we get lots of heavy rain here in FL. I was considering doing the exact same thing with the "doghouse". I was thinking it might present a problem for cooling/airflow, though. I had considered one of those solar fans for the roof of a house. The problem with that is the combined cost makes me doubt the economics of doing that vs buying a new pump every few years. Hopefully someone else can weigh in on the merits of the idea.
kelemvor
Exactly.
The ideal solution is probably to raise the pump a bit - a split or partial 2" patio block is enough in most situations, AND to put a roof over the pump, but NOT sides.
Great idea raising the pump up 2" or so. I will definitely do that at the end of the season since it means some plumbing modifications. Mine sits on a pad but it's only about an inch above the surrounding grade and the area is covered in that ground cloth that prevents weeds from growing up everywhere. I'm thinking since that ground cover doesn't drain very quickly, if it gets soaked, perhaps the water level in a very heavy downpour might be rising up to the level where the motor sits.
As far as the "doghouse" goes, I did say "roof." I may not know much but I do know that if the motor has vents it's going to need airflow... I wasn't planning on totally enclosing the motor but thanks for back-stopping me.
Would it be overkill to disconnect the motor and bring it inside during the winter months? Or would that just wreak havoc on all of the seals that keep the water out from between the pump and motor? I'm not looking to create more work for myself, just curious since our season is only about 4 months long here. I do remove the SWCG cell during the winter months so there's no chance of any water being left in it and having a freezing problem.
RandyM1911
I wouldn't remove the motor. But what is possible is to re-install the pump with 2 unions, and replace the electrical to the pump with a locking cord, using something like this:
L6-30 Extension Cord, 20 Foot - NEMA L6-30 Plug to L6-30 Connector, 30 Amps, 250V
Arlington LPCG50-1 Low-Profile Strain Relief Cord Connector, 1/2 Inch
American Terminal AT-31604 60-40 Rosin Core Solder
You'd have to cut the cord, and put the female end into the box, and attach the male end to the pump, using the strain relief connectors at both ends. You'd need to make sure that water didn't drip all over the plug & socket set. You'd also need to solder the wire ends, especially on the motor connections. Fine stranded wire will not maintain a good connection under those terminals, with all the vibration and such.
But, with the unions and the cord set, you could simply disconnect the entire pump and store it indoors.
Hmmm, interesting idea. I would actually only need one union (which I plan to install anyway since I'm re-plumbing for a different motor height) because the pump outlet to the filter is plumbed with a piece of clear reinforced flexible hose attached with a hose clamp.
I'll have to think about the electrical connections and come up with a way to protect the coupling from the elements.
Thanks for the suggestion.
Did I say something about not wanting to create more work for myself...? D'oh!
R-
Well, you don't have to do it all at once, if you don't want.
