I don't know what the commercial heaters use in their heat exchangers, but I suspect it would be stainless steel.
Would there be a problem with using copper pipe in a home built solid fuel heater? If there are serious cons to this, I do have another method in mind, it just involves a lot more work, along with lower efficiency.
Would copper tubing require keeping a really close watch on pH? Would I be introducing copper ions into the pool? I've seen via the internet, many examples of people using copper in home built heaters, but with my lack of knowledge in this area, are they asking for green, copper laden pools?
Thanks for any info you can provide!
