Your PF is 3.4. 10% chlorine -- if it's still full strength and if it's boxed bleach, it almost certainly is NOT -- contains 10% x 8.5lbs, or 0.85 lbs of chlorine. Multiply your PF x your available chlorine for 5.8 ppm of chlorine IN YOUR POOL, per gallon. In other words, 2 gallons of pool store bleach will add up to 6 ppm. 2 gallons of Walmart bleach (6%) will add about 3.5 ppm.
The fact that you added 2 gallons, and only reached 1.2 ppm tells me your pool store bleach is probably weaker than Walmart bleach!
Your husband is right -- 1 - 2 gallons should be more than enough per day, IF
+ your pool was algae free (but it's not!)
+ had no other chlorine demand (but it doesn't)
+ the pool bleach was full strength (but, in August, it's not)
=> Algae can collect in cracks. Both mustard and black algae do this. BOTH types are VERY chlorine resistant.
=> Adding chlorine, without adding ENOUGH chlorine to kill them, just leaves you in a Vietnam style conflict with your enemy, in which both sides take huge losses and neither side wins. You've got to make up your mind about whether you're willing to do what it takes to win.
=> There's no 'free' way to clean up your pool. We can help you do it better, and for less than a pool store would, but on a 35,000 gallon pool, you are going to have to spend several hundred dollars to get rid of your algae and clean up your stains.
I don't mind spending the money if we get a clean pool, money to me is not the biggest obstetrical. But my husband is still not getting this. (sigh)
=> You haven't 'lost' any time waiting for the kit: if we take off and start treating your pool without testing and proper prep you could spend several hundred dollars and accomplish nothing.
True
=> The "PoolCalculator" (poolcalculator.com) allows people to calcuate exact doses . . . but that's only helpful if you know the other stuff you need to know. For example, The PoolCalculator won't help you figure out that your 10% labeled bleach is currently probably 4%! You'd probably end up thinking the PoolCalculator has a math error.
=> This is extremely difficult water:
FC - 1.2 ppm
CC - 0.2
pH - 7.0
TA - 120 ppm
CH - 875 ppm
CYA - 90 ppm
I don't recall ever seeing a calcium level that high, before.
=> Under the circumstances, what I'd recommend is
+ Realize you can NOT use cal hypo (calcium will turn your pool to milk), or
+ Trichlor or dichlor (will add MORE stabilizer)
+ Which leaves bleach . . . BUT your pool store bleach has 'cooked off' in summer heat;
+ Which leaves you buying dozens of gallons of Walmart bleach!
+ 10 gallons tonight; and 10 gallons tomorrow night + brushing would be a start.
He's at Walmart now getting 10 gallons of chlorine. But he keeps insisting on getting the 10% pool chlorine, saying it's cheaper. He agreed that the chlorine he bought before was probably dissipated as he buys it at Home Depot and they keep it in the shade but it is outside. I have to work tomorrow, so Monday I'm going to Walmart and get 10 gallons of plain bleach from the laundry area.
+ You MUST keep your pH low, so you need to read the muriatic acid page (see my signature), and get a couple of gallons at Lowes.
pH was 7.0 yesterday, will check again today. We still have about 1/2 gallon of muriatic acid on hand, I can get more.
+ Once the algae is under control, you have to lower your calcium, because HEDP won't work properly with that much calcium in your water. That's a major process, too.
Then I guess it not a bad thing that I don't have the HEDP yet.
+ You need to order polyquat, because that's the only thing you can leave in your water while you are messing with all the other stuff.
I did add 32oz. of polyquat, so I guess this means I need more.
+ Once you have controlled the algae (not: eradicated -- that's probably not practical, right now!) and lowered the calcium, THEN you can tackle the stains.
At this point I am putting stain removal on the back burner.
+ The only easier path I can think of, is drain and refill, BUT you need to (a) check on the cost, and (b) make sure it will help by testing your fill water and making sure IT doesn't have super high calcium, AND (c) check to make sure there aren't local restrictions on draining and refilling (you are in California, where such restrictions are common).
Don't think our county has those restrictions, but I'll check.
+ To make SURE you are testing calcium correctly, please watch the Taylor calcium videos on this page:
http://www.poolforum.com/pf2/showthread.php?17157
OK I did that test now 3 times, 2 times with the instructions to counteract possible high metal ions interference.
I got regular test; 875ppm
interference test; 750ppm both times.
So . . . it's up to you. What do you choose to do?
