Well due to a bunch of rain, too much water and a leveling/placement issue, I drained my pool last night.
I was afraid of a collapse and didn't want to take any chances.
I'm going to try and move the pool back a cpl inches and put blocks under the legs on a low side and see if that helps. You'll see in my pics that the legs had no where to go so started moving to the left putting more water force on that wall and causing the wall a little farther down to want to buckle in from being pulled by the low side high water side.
I was in the middle of the Shock Method for Algae that was starting due to not chlorinating enough while filling the first time. My question is, Do I need to do anything to the bottom of the pool as in cleaning it before I start filling? It looks very clean but I know how bacteria are good at hiding! I plan on adding bleach as I fill this time like I should have done in the first place.
The Wall Buckle
http://i307.photobucket.com/albums/n...L/IMG_0554.jpg
The BIG Shift
http://i307.photobucket.com/albums/n...L/IMG_0556.jpg
No Room for Legs
http://i307.photobucket.com/albums/n...L/IMG_0559.jpg
Close up
http://i307.photobucket.com/albums/n...L/IMG_0560.jpg
What a job this has been! My bruises are just starting to fade but I see more in the near future! lol
