First let me start by saying that this site and forum is AWESOME and as a result I gained the courage to drain my 12' AG Intex and take over all duties and maintenance of my neighbor's IG pool as no one has the time or willingness to learn and maintain it properly so in return me and my family have unlimited access which thrilled my 6 yr old son to death. I think it's a pretty fair trade, not to mention I have really enjoyed every minute of learning everything I can.
These are the specs about the pool that I do know without walking over there and getting the rest since it is currently raining.
- 21,000 gal IG rectangular vinyl.
- Deep end is approx 6'
- shallow 3'
I also know that the pump is a little dated, does not use salt, but works very well I think. Right now we have been running the pump 24/7 and backwashing as needed etc. It has one skimmer and two jets where the water flows back in. I will try to get the pump info next time I go over there. The owner does not have an automatic cleaner so i do have to vacuum manually every time but I actually enjoy it. Currently we use the dreaded pool store chemicals but as soon as I get her a shopping list together and a good test kit, we will be switching to the BBB method.
The test kit I have is just the basic one from walmart that tells chlorine and pH but pH is not accurate when chlorine levels are above 5. We will be able to purchase the Taylor test that you recommend toward the end of July but until then I refuse to take water sample to local pool store because they use the strips and then enter it into the computer which I have learned from here is very unreliable and that is the only pool store within quite a distance from us!! So I will try to wing it the best I can until we are able to get a good test kit.
So far I think I'm handling everything pretty well considering my resources and besides the aggravating frogs, and an episode of millions and millions of frog eggs laid one rainy night, I haven't had to deal with any big issues. The liner was just put in at the start of the year so that helps a lot. Any questions I have had have been answered by reading thru the forum, which I have been doing for a few weeks until today when I decided to actually register!! Any advice is always appreciated as I am a newbie at this but I have def been doing my "homework". Let me know if you need more info or anything to make your job easier!!
