Converting 15' Round Intex to Hard Plumbing
First of all let me say thanks for all the informative threads on this forum and to those who provide the replies.
I have been able to search and get quite a few of my questions answered without ever asking them...
I have a 15' round Intex pool. It has the metal frame but not the "ultra" sides.... I have the 16" sand filter and I am currently using the Intex adapters to adapt the larger hoses with this pump to the small connections on the pool. However, my plunger on the intake side must have an air leak in it, as I am getting air into the pump and have all the connections as tight as can be without stripping.
So I am going to hard plumb everything with 1 1/2 Sch 40 PVC.
Thanks for those who came up with the idea of use the 1 1/2 electrical conduit connector (gray) to adapt between the Intex connections and 1 1/2 PVC.
I was planning on cutting the liner at the current inlet/return connections to fit the larger Intex connections. Is there any advantage to using a standard pool connection vs the Intex? Has anyone done this with success?? Do they even make standard connectors that would serve this purpose?
I desperately need to come up with a usable vacuum solution.. Is it worth cutting the liner and plumbing a separate vacuum port?
I really like the idea of a thru wall skimmer, however I am not sure if the liner can support the extra weight and stress. Any one done this with this type of pool?
Thanks all!
Ryan
Re: Converting 15' Round Intex to Hard Plumbing
Don't try to connect hard pipe to an Intex.
There are some vacuum adapters you can use, possibly something like thisIntex Vacuum Tube Adaptor
However, I am NOT recommending that, because I'm not sure it's what you'll need, or even if you will need it. Also, I hate to see a $9 shipping charge with a $9 item -- that's not a ripoff necessarily, but I'd rather find a better way.
I'm going to be setting up a couple of Intex pools in the next week or so, and will be using them to test different products.
This vacuum system is being marketed for Intex pools, but it has mixed reviews and sounds fairly fragile:Skooba Pool Vacuum Kit
A more standard vacuum set up can be adapted to an Intex pool; if there's not something being sold, I'm sure I can work something out at Lowes:Poolmaster 27514 Classic Full View Triangular Vinyl Liner Vacuum
Hydro Tools 8365 8- to 16-Foot Adjustable Fluted Premium Fluted Telescopic Pool Pole, White
Hydro Tools 1-1/4-Inch Diameter With Swivel Cuff Pool Vacuum Hose
Unfortunately, I can't be any more definite than that, yet.
combined similar threads.
Pool Doc,
Can you elaborate on not hard plumbing an Intex? I have seen several posts on here that appear to have sucess...
My biggest concern is the point, where the plunger needs to be adapted to fit the pool..... it is a compresssion type adapter and is very loose..... I can take a picture when I get home and post.....
I think you could do it, without problems . . . at first.
But an Intex pool moves easily, and hard pipe doesn't. That is going to create a stress point that will either tear the pool or break the pipe. I think fixing whatever is wrong with your existing Intex connection point might be a better plan. If you can get through on their phone lines, Intex has apparently been pretty good about replacing components that have a problem, often not even asking that you return the old component. I'd try that, first.
Consumer Service: 1-800-234-6839
Special Summer Hours: Monday through Friday 7:00am-5:00pm PST; Saturday 7:00am-3:00pm PST
Online Store: http://www.intexstore.com
Main site: http://www.intexcorp.com
By the way, thanks for the subscription!
You are welcome. For all the free advice, its the least I can do!
You bring up a very good point...... Maybe I will abandon the hard plumbing....
Here is another idea...
The pump came with intex ports, that fit the include hoses and plunger valves.... just not the pool... I am thinking about just cutting the liner (it is reinforced where the cuts will be)... and using the following ports (not sure if that is the right word).... They have gaskets and all...
http://farm8.staticflickr.com/7136/7...666f6509_m.jpg
connector 1 by atc_nh, on Flickr
http://farm8.staticflickr.com/7112/7...6a304e93_m.jpg
connector2 by atc_nh, on Flickr
Here is what I am trying to eliminate.... basically, its a rubber sleeve with a plastic pipe inside.... The plunger requires an adapter which uses a nut to compress around the rubber sleeve.... It is not tight at all and the slightest movement cause it to slip.... Only a matter of time before it falls off and I loose my pump :(
I am going to cut all that out and replace with the fitting from my above post.....
http://farm9.staticflickr.com/8145/7...01d1dcc5_n.jpg
Untitled by atc_nh, on Flickr
Thanks again for all the help!
Are you planning to dump your water or wait 'til the end of the season?
I think your plan should work so long as all your cutting is in the reinforced section of the wall and you snug those new ports up tight. I'd use teflon tape just to make it eaisier to turn the nut.
Measure twice, cut once.
Ryan, I modified my "little" Intex pool with the big intake and returns since they came with the big Intex pump/filter. At this point in time, unless you are willing to live with the leak you will have to drain at least some water out of your pool.
You will have to cut around 1/4 of an inch of material off to allow the installation of the bigger return in the hole. You will be OK by just following the installation diagram of the parts installation guide. THEN you can hook up your big hoses with the valves and all will be well. I have hard plumbed after my first 6 foot of hose from the pool (the pool bends and flexes so you have to allow for movement....period).
However, all conections to Intex equipment are connected with intex hoses first (for the length of the hose) then to the hard plumbing. You will find that if you use a 1 1/2 rubber PVC pipe connector cut into 1/8 inch washers (similar to your garden hose washers), you will have no leaks when connecting 1 1/2 inch Intex hoses to a 1 1/2 inch PVC threaded connector. You WILL have to make or buy a washer. Cutting is very easy if you put a 1 1/2 inch PVC pipe into the connector, then using your cutoff saw you will be able to make repeatable cuts and similar washers.
Bob E.
Thanks everyone for the replies.
I went ahead and cut out the small intex connections and replaced with the larger.
Everything is working well, and flowing better.
Safetybob,
Do you still use the intex plungers??
Ryan
A little late replying, but yes, I still do use the Intex plungers. Incase I didnt' say it, I also use the "big" Intex inlet and outlet, plungers that came with the big pump and the 1 1/2 inch hoses. I may also work on hard plumbing a bit more next year. Found 1 1/2 inch pool/spa cream colored tubing at Lowes to try out. Looks heavy duty enough, but problem is connecting it to our unique Intex stuff. More experimentation needed.
Glad everything is working better.
Bob E.
