Got this from my email, from the starter area thread, snipped to answer questions.
				Originally Posted by bigdave
			  With less water and poor filtration, things can go south in a hurry.
  Agreed. I've already seen what the lower volume of water can do.
			You seem to be heading in the right direction (and you're in the right place to learn) as far as maintenance and chemistry but I haven't seen yet where you've ordered the K-2006 aylad recommended.  My opinion: it is the single most important start-up chemical for a new pool.
  Again, I agree on all points. See my first post here about the K-2006.
			I've never see a through-the-wall skimmer for soft side pools and can't imagine how it would work.
  I have abandoned that idea, as the tension on the sidewall of the pool is rather high. I doubt that the bolt holes would hold against that tension, even with a lot of reinforcement.
			As far as additional returns: I wouldn't want to cut the pool and the one should be OK for a 15' pool.
  My thoughts on this are that the corrugated tubing that comes with the pool presents very high resistance to water movement. I do plan on replacing this with flexible PVC piping for next year. This alone will most likely take care of the low flow problem.
			....I supppose putting it in a hole could work, I just don't see why.  You'd need to modify the ladder.  Does your pool have the rope that goes around the bottom of the legs to hold them upright?
  I understand about the ladder mods. That would be a minor problem, as the legs would also have to be shortened as well. Yes there is a rope. I have already noticed that any movement of the water allows the legs to "walk" and I am constantly having to reset them back into place, even with the rope as tight as I dare make it.
			There are pump / filter choices in the Intex world (all cost more than a K-2006), sand and cartridge.  Ben has made some recommendations for filter cartridge upgrades that you may want ot consider in the Construction, Equipment, Operations, Seasonal Care (P)Intex-type Pool Setup & Operations section of the forum.  There's probably a lot of stuff in there you want to read anyway.
Good luck and have fun!
  Yes, I am reading some every day in that section, along with many other places here, to the point of information overload at times. I'm the kind of person that (pardon the pun) "dives in head first" when presented with a new challenge. I seem to be at my happiest when I'm learning new things.
@Aylad -- This thread should answer your additional post in that thread as well.
The reagent question -- Found it on amazon, for a good price. I'll order some when I order the K-2006.
Charlie
