Opening with very high ph and mustard algae
I have a 52,000 gallon pool that came with my house that I bought 6 years ago. I did the store thing as everyone does and found your site while looking for answers to mustard algae and the fact my cover went bad. I decided to go without a cover with advice I got from this forum.
Closing in the fall was complicated with a hurricane, no power for 10 days follwed by a strange ice storm 60 days later. I starting opening today and am planning to use your BBB advice. My ph is pink and the water has that mustard look to it. My pool is almost filled but I need where to go from here. I have not put anything in yet.
Lastly, I can feel that the sides of the cement pool is now rough and used to be smooth.
Thanks!
Re: Opening with very high ph and mustard algae
That is a big pool! The first order of business will be to order a good kit. The one we suggest is the Taylor K-2006 or 2006C which you can get through the testkit link in my signature below. (Can't buy it locally.) Another kit that you might be able to get (not as good as the Taylor but OK) is the HTH 6-Way kit. Some Walmarts stock it, others don't. What are you currently using to test with? If pH is pink that is probably high but we need a value to know for sure. You need to get some chlorine in there. If you can supply us with a CYA reading, we can make better suggestions to help you.
If you can't find the 6-Way kit, you may be able to get a reliable pool store to test the CYA for you while you wait for your Taylor K-2006 to arrive. Just don't let them talk you into buying a bunch of stuff.
Report back with a CYA reading as soon as you get it. In the meantime, add some chlorine. It's gonna take a lot of bleach, but I would suggest adding 10 gallons of plain, unscented household bleach (generic is fine) to your pool this evening. Once we know your CYA reading, we may make a different suggestion. If you have none or little, dichlor may be a good option for you as it wouldn't be as much of a hassle as so many bleach bottles will be. If your pool store sells liquid chlorine (which is usually 12.5%) that might also be a good option for your pool.
Keep your pump running 24/7 and clean the filter as needed. What type of filter do you have, by the way?
Welcome to the Pool Forum!
I did by the kit kit over the winter as you suggested and the ph was so pink that it was over the 8.0 (I assume)
Shall I do the cya reading?
Yes. Do a full set of readings and post all your numbers and then somebody can help you go from there.
cl. No reading
cya 35
ph. Past 8.0
Calcium Hardness. 150
TA. 80
Also, I have a sand filter.
That's a big pool. Trying to handle it with 1 gallon jugs of 6% bleach will be a pain: 1 gallon would add only 1 ppm of chlorine!
- Do you have any chemicals on hand? If so, EXACTLY what are they?
- Is the pool covered? If it is, leave it covered, till you have chemicals AND a plan ready to go.
- Do you have access to commercial liquid bleach OR 100lb containers of granular calcium hypochlorite?
- What is the make / model of your filter & pump?
If your pool is NOT covered, and you have access to a Walmart and Lowes / Home Depot, I'd recommend adding 15 gallons of bleach in EACH evening. Add 2 gallons of muriatic acid (link to guide in my signature!) daily, but at least 30 minutes from when you add the bleach. Once we have more info, you can work out an alternative.
If possible re-test chlorine 1 hour after you add the bleach for the first time. If you had higher CYA last fall, you may now have ammonia in your pool. Dealing with that on a 52,000 gallon pool will take more than bottles of bleach, unless you want to go to multiple Walmarts and buy out each one's stock of plain bleach!
Thank you for your help. Since I found you in the winter, I have been stocking up with chemicals. I do not have a cover as it died in the fall and that is how I found your site.
I have dichlor, lots of bleach, 20 gallons of liquid chlorine, borax and baking soda.
My sand filter is a large sand filter by Hayward and a 2 1/2 HP motor by Jandy. The filter is new.
Thank you water mom and doc. I am doing the suggestions you gave me and will do the reading again as I just got the filter going and added bleach.
I just paid the $14 to join so I do thank you for your help and hope to use this forum often.
An hour after adding chlorine and bleach, my chlorine level is:
FC. 9.5
CC. 2.5
This was my first time using the k-2006c so I will have to learn how to use it correctly.
I guess I will see how things look in the morning.
Thanks!
Get some acid -- you need to get the pH down below 8.0!
Also, we'll need make/model on the pump and filter in order to offer better advice.
Water looks 100 percent better today and is very cloudy but no longer disgusting. I will get reading after work and buy acid after work. I ran the filter on recirculate last night but changed to filter this morning.
Hayward Sand Filter. S270T2. Pro Series High Rate Sand Filter
Jandy 2.5 HP Uprate pump. MHPU Series - could not find model number yet
Thank you again for helping me!
Here are the readings I got today. Put in Tabs in chlorinator as well as lots of bleach and liquid chlorine. Put in acid today as well.
FC 2.4
CC .8
TA 70
PH 8
Calcium 200
Given your low TA, I wouldn't try to push the pH below 7.6 right now. Have you tested your stabilizer level? That's critical to know.
Then, till the algae is gone, try to dose to 15 ppm (15 gallons of 6% bleach) and repeat before levels go below 5 ppm.
First of all thanks for all your advice
Was away for 5 days and had to do what I could before I left.
FC and CC need major dose when sun goes down
ph 7.4
TA 50ppm
CH 130ppm
CYA - The black dot does not disappear even after I filled the tube to the top.
Thanks!
