Re: Cloudy water & new Intex 2500 gph pump
I called Intex yest. and they emailed me some papers to fill out and are willing to send me a new pump. BUT, I decided to rinse out the cartridge filter and by jove, the output flow was good again.......for an hour! I rinsed the filter again and the same thing happened. I will try to post pics of the cartridge (guess I didn't subscribe for that) anyway. it wasn't that dirty (to me anyway--it has some brown stuff on it in places but not covered) compared to the green algae that covered the old cartridges on my 1000 gph pump when I first opened pool which were nasty and still allowed the out take to flow ok for hours!!
Also reposting a q I had in earlier post
Hi!
I just joined as a member. Was having a hard time figuring out where things were posted. Still have cloudy water after 3 days of adding a gallon of bleach each evening but it's bluish now and not green. I have not gotten a good test kit yet and not sure about the CYA. Added a pound of stabilizer 2 weeks ago but it says not to clean the cartridge filter for 72 hrs after adding stabilizer and I want to change it constantly to get the algae out and it's almost gone now. The test I have is showing deep yellow to orange so think it's working. How long should I keep adding the chlorine for?
You need to keep adding the chlorine for the whole time the pool is up....but you need to keep it at shock level until the green is completely gone and you are not losing any chlorine overnight (testing in the evening and again in the morning before the sun hits the pool). At that point you can let it come back down to normal levels, but you really need to know if you have a CYA reading because that's what your chlorine levels are based on (see the "best guess chlorine chart" link in Pooldoc's sig).
The vBulletin attachment feature is BROKEN from the factory; it seems to loose all the pictures every time I have to do an update. Do NOT use it.
If you have a Flickr or Picasa or other image account, you can post the pictures OR you can email them to me at poolforum@gmail.com . Either way, I'll eventually move them to the PoolForum Picasa account, since that way I don't have to worry about the pictures getting lost.
Most Intex owners put their stabilizer in an old sock, and hang it in front of the return where water re-enters the pool.
poolpuppy
... the output flow was good again.......for an hour! I rinsed the filter again and the same thing happened...
This is good! it's getting the crud out of your water - wash the filter every time it slows down. Have you considered Ben's suggestion about getting Unicel filter carts? Also you need test kits. HTH 6-way from wall mart is a good start (if your wall mart has it) and do order a k-2006; you'll be happy you did.
