PoolDoc note: Original poster is in the London, England area -- do not give North American specific advice!
Hi James;
There are several possible issues:
1. I'm not sure how you obtained 15% bleach, but if it was from a pool dealer rather than an industrial supplier, than there is an excellent chance it was 15% when shipped, but less than 8% now. The stronger bleach is, the fast it breaks down . . . and 15% breaks down quite rapidly indeed. I know that London had an unseasonably warm March, and if it was stored from last fall till you bought it, odds are it was NOT at label strength. That would turn your 60 ppm dose of chlorine into a 30 ppm dose of chlorine, or less.
Dry forms of chlorine are likely to have retained their strength.
2. You'll need to test your stabilizer level. I know you can't get the K-2006 kit -- they've been un-shippable since 9/11/2001, but you should be able to get the Palin or Lovibond tablet based test. High CYA could produce the results you have.
3. DPD tablets will not give you reliable tests in this situation. If your residual chlorine is above 10 ppm, tablets are likely to give a zero reading. You'll need to find some test strips that have syringaldazine pads (turns purple) or, better, a kit with OTO (turns yellow) drops.
