We have an Intex 16'x32'x52" pool. I use a sand filter and cartridge filter because we use a salt water generator. For the winter we left about 3' of water in the pool and balanced water. Then we super chlorinated and added pool magic. We had an unusually warm winter this year, needless to say the pool only froze about 1' which means some algae and other contaminates invaded. Upon opening the pool I added water and super shocked the pool to kill algae and since I like to manually filter metals out of the pool I like to separate them from the water by keeping chlorine levels high so they will filter out, thus I don't fight them all summer. Because this requires frequent back washing and vacuuming to waste I have not messed with my PH and alkalinity yet because I don't want to waste money adding chemicals only to drain them. When I opened the pool the water was moderately green. Then it turned dark brown from metals after shocking. Upon a week of filtering I think I have the metals out. Also, since I kept the chlorine levels at around 12 ppm to effectively kill algae I assume I killed all algae. However, my pool water is still light green to a bright yellow. I tested everything even copper thinking maybe that was causing yellowing. Copper is zero though. My PH is 8.2, alkalinity is 240, chlorine has been steady at 12, hardness is 100, and stabilizer at 40. I know I need to add acid to lower PH and alkalinity but would like to get water back to clear first. This year I am using muratic acid no mor instead of acid because it's so toxic and I cannot breathe it in being pregnant. Do you know the conversion of this versus muratic acid? Also what can I do to get my water clear? I did the overnight algae test and my chlorine level has remained constant for two days. I am lost as to what I need to do. I am tired of wasting money on chemicals but want a nice pool once the weather warms up. Thank you!
