Fiberglass pool badly stained
So glad you guys are back :)
Might as well be among the first of the needy !
Background, have a small fiberglass pool that uses a heat exchanger and a zone off our our boiler for heat. Works great. Last year I noticed that below the water line was becoming stained and couldn't figure out why. Tried metal out, jack's magic and a couple of other products with no results. Fast forward to now, pool is drained down about 1/3 and the staining is really bad, about the color of oak from the water line down. Figured I'd try some muriatic acid on a test area and it worked great for bringing it almost back to white. Gave the test area a good rinse when I was done.
I found the source of the metal and it was a couple of galvanized pipe elbows off the heat exhanger, they were very badly corroded inside. Replace them with pvc.
Well that a lot of baggage but there are a couple of questions coming:
I want to drain the pool, dry it, spray it with acid, rinse it and then refill it. Not much ground water underneath me, yard is quite sloped and the pool is at about mid yard. Anything to be aware of when draining it?
Next, muriatic acid and fiberglass, good idea or bad idea? Any precautions other than glasses, gloves and ventilation?
Last one, I'm sure there'll be some metal in the water still when I'm done, how can I get that out and prevent staining in the future?
Thanks for any help.
Mark
Link to Ascorbic Acid in Bulk.
http://www.chemistrystore.com/Ascorbic_Acid.htm
The difference between food grade and not is that when they get it in the box form from the manufacturer it is food grade. Once they re-package it in smaller quantities, it can't be sold as food grade. I found this out because last summer they ran out of the non-foodgrade containers, and he called me to ask if I would take the bigger box.
It is the exact same product as the pool store "Ascorbix" and the like and much cheaper. However, Acorbic acid does not fix your problem, it only helps you return the stain to "a solution". A sequestering agent, which you will have to buy at the Pool Store will "hold it there".
Read the Pool Docs Thread regarding Metals and Staining. All pools are different. And I have not found one pool store or pool maintenance company here in Southeastern Mass. that even remotely understands the concepts of this Forum.
I have a 35,000 gallon vinyl lined pool with a heater.My metal comes from my fill water, which is a well. The fill water has a very low PH {5.5}and High Mangenese. I have a very hard time maintaining the PH at 7.0 in my pool.
I chlorinate my pool with nothing but sodium hydro chloride, using a liquimate feeder in a 5 gallon gerry can, and 1/2 to 1 gallon of 12.5 per night.
I never allow my stabilizer level to go over 40.
Filter is 6 hours on, 6 hours off. The liquimate adds just enough SHC to keep me chlorinated . This formula keeps me stain free until the squestering agent wears off, or my ph rises to 7.4, at which point the metal falls of solution and stains my liner. Then I add the acorbic acid, it magically disappears, and the circle remains unbroken.
Good luck to pool owners with wells.
Re: Fiberglass pool badly stained
Thanks all for the advice. Some good stuff in there.
I've been waiting until I had some info to pass on but unfortunately just looking for more advice.
I finally got in touch with someone at the pool manufacturer who had somewhat of a clue. Can't drain it or I void my warranty. They recommended proteam metal magic and said they would ship me some. Been waiting 3 weeks now, calling every couple of days and hearing excuse after excuse of why it didn't ship yet. I'm skeptical that it will work anyway. I've probably spent $300 bucks or so in the last year for metal something or others that did nothing but take the green color out of my wallet.
I read with interest about vitamin c. I took a tablet that I had, rubbed it on a spot for 30 seconds or so and the spot was nice and white after. Looks like it might work.
I also read about adding muriatic acid to the water to bring the ph real low to dissolve the stains then add a metal remover to capture and filter it out. Unfortunately no details other than read the bottle. The bottle of course doesn't say "If your a moron and have badly stained your pool add this amount" Anyone heard of using that?
I know I can get muriatic acid locally but not bulk vitamin c. I'd have to wipe out the vitamin section from every walmart for a 20 mile radius.
Anyone heard of the muriatic acid route before?
Thanks for all the thoughts and advice,
Mark
hoogie, There is a link to an online supplier of bulk ascorbic acid (vitamin C) on the first page of this thread.
Here is another link in case you want to get 5 lb.:
http://www.msm-msm.com/store/agora.c...scorbic%20Acid
You bring your ph down, and lower your chlorine (the ascorbic acid will be used up by the chlorine) Just pour the ascorbic acid down the walls of the pool as you walk around. Put the filter on circulate, dump in enough metal sequesterant for the size of your pool and let it circulate till you see all the stains magically disappear! It doesn't take long. Then put your filter back to filter and keep it on 24/7. After 24 - 48 hours you can start to SLOWLY bring up your chlorine level. If you have a sand or DE filter you can put a chlorine puck in the skimmer, which will help to let the metal stain the filter instead of the pool. Youwill also have to bring up your ph level. After a stain treatment it is hard to keep the ph and chlorine up. Don't let the ph go higher than 7.2 for a while, and do not get your chlorine up to shock levels for at least 2 weeks. High ph and high chlorine will make any metals in your water percipitate back out to land on the pool. If you have any questions feel free to ask.
Okay, here's an update. Happened to stop at a pool place today and they happened to have absorbic acid. Bought 10 lbs. I explained my dilemna to the pool guy there and he said to take 5 lbs, mix it in 5 gallons of water and use a mop and swab in onto the sides, bottom, steps, etc.. -- even though they are underwater. I did that, pain in the butt.
I also took an extra step and sprinkled the last 5 lbs down the walls and onto the stairs and benches. Threw in a half a bottle of stain-x for metal, put the filter on recirculate, closed the cover and let it run for about 7 hours. Chlorine was nil and ph was about 6.0 when I started.
Well, just opened the cover and it did NOTHING. Still brown as ever... I'm bummed. I'm seriously considering just draining it and spraying it with muriatic acid which I know takes the brown right off. Nasty stuff but it's turning into a money pit otherwise. Besides having brown walls, the water is cloudy and looks like crap and will probably take a bit of work and $$ to get it right after this. I'd seriously like to just start off fresh.
So who can offer advice about draining my 11x24 fiberglass pool safely? Manufacturer told me not to as it voids the warranty.
My yard is sloped so I know there's no standing water underneath it. Concrete deck all around so chance of cave in is minimal.
I may rent some trucks jacks for support, gas mask of some type and then just spray away, wipe clean and refill it. Shouldn't be empty for more than 24 hours. BTW, the pool is enclosed so no elements to worry about either.
Anyone have any other advice I should consider?
And again, thanks everyone for the well thought out responses. I knew this was going to be tough one.
Hoog
I really don't understand - if a vitamin C tablet worked, then the ascorbic acid should have worked. The low ph and no chlorine should have made this a snap. Are you sure it was ascorbic acid or oxcylic acid? I am really stumped. You can contact the pool company and ask them the best way to drain - they have to drain them when they have to fix cracks on the bottom. I have a friend who had to have this done, I will call her tomorrow and ask her how it was done. You must really be frustrated! I feel your pain. Keep the faith!!
I'm finally stain free !!
What I tried with the pool filled with water:
Jack's magic
Abscorbic acid
Oxalic Acid
Proteam Metal Magic
Various metal stain removing agents
Scrubbing
Vitamin c in a sock
Abscorbic acid was the most promising but it only lightened the stains a bit even after 20 lbs in a 7000 gallon pool.
What finally worked for me:
Drained pool
Sprayed sides and bottom with a 1 to 1 mix of muriatic acid/water.
Tougher areas got straight muriatic acid.
Rinse pool, drained whatever water was left.
Refilled pool and used a metal remover, sorry can't remember the brand but was used as a precaution.
Muriatic acid is nasty stuff and even with protective clothing on I got a few burns on my skin. 1 to 1 mix didn't smell that bad but the straight stuff had a gagging smell once applied and if it weren't for it being a good windy day when I did it, I'd probably be dead.
Not suggesting that anyone else drain their pool but for me after probably $600 in metal removers, scrubbing, mopping stuff on under water, etc. draining and spraying was a last resort and it worked beautifully. My pool and water look cleaner and brighter than ever. If I ever run into this problem again I'll be draining and spraying in an instant. It took one day from start to being full of clean water again.
Thanks everyone for all the suggestions and support.
Hoog
Congratulations!! Now, enjoy your pool.
