First, let me say I am so excited to find this forum. I spent about 2 hours last night just reading threads. I have an algae problem, but I think I know how to attack (and be patient!) about that issue.
My bigger concern right now is with my multiport. I opened my pool two days ago and it filtered just fine for about five hours. Then, a small stream of water started pouring from the port that releases the waste/backwash. I called my pool store and they told me that it was likely the gasket that seals the two pieces of the multiport together. They told me how to take is apart. I did so, found the gasket, and couldn't see anything wrong with it. Additionally, I bought a whole new filter system and pump last summer in July and closed my pool at the end of August, so I was doubtful that it was damaged, but I took their word for it. They told me to bring the top part of the multiport it, that they had a replacement. My pool store is 1 hour away, but I made the trip.
The first guy that waited on me looked at the piece and said, "this doesn't look damaged." When I gave him the name of the other guy that I had talked with on the phone and told him the situation, he said, "ohhhhhh, yeah, it would have to be this piece, then." They replaced the portion of the multiport that had the gasket and I proceeded home, put the new piece in, started the pump and...you guessed it, there is still a leak out the waste port. The new piece had no effect whatsoever.
Before I call my pool store again (and end up making another 2 hour round trip drive to the store), I thought that I would ask you all for advice. I did rig a hose from the backwash port back into the pool, so I can still run the pump without water loss, but I don't feel comfortable leaving it on when I am not home or a night and with an algae problem, as you know, I need to leave it on 24/7.
Thanks in advance.
