Water temperature for salt to be added.
The wife and I just put a salt water pool in at the end of last year. We have put liquid chlorine in and ph+ to get the pool going. The SWG is still off and I was wondering if the water temperature has be at a constant temperature to add the salt.
This whole pool thing is still very very new to us. I have discovered that I do need to get a better water test kit and that our hayward king ray doesn't work very well.
Re: Water temperature for salt to be added.
Salt dissolves easily in just about any temp water- you can get the salt in at anytime pump is running to keep it mixed! May be a little slower in the cold, but not much...
Ok, thanks.
Also we have the test kit that the pool builder gave us. I tested the water today and it is showing no chlorine. I shocked the pool two days ago with 3 Gal of liquid chlorine. Do/or should I add more. It is pretty clear and looks good. The ph is showing good.
its a vinyl IG pool with about 27000 Gal.
You need to tell us what sort of kit you have: most likely, you have no chlorine and need more. But some kits (DPD tablets) will read zero if the chlorine is zero, but will ALSO read zero if the chlorine is high!
You can get a cheap Walmart OTO kit (drops turn yellow) and test with it -- it's not super accurate, but it is super reliable, and will always give you some indication of what you've got (yellow = typical chlorine range; dark yellow to orange = high chlorine, to really high; brown = too high to swim.
Ben
The pool kit that he gave us does have the yellow and red liquid to test the chlorine and the PH. The test that I did today didn't show any chlorine after putting in 3 gal of liquid CH on friday night.
The test kit just says test kit nothing at all else on it. I'll have to look at those kits to see what they have. I know that there is a pool center just down the road that will test the water for everything and give you a print out for free. They are however closed today or I would run out there and have them run a test on it.
I was thinking about putting two gal of liquid CH back in and then start adding the salt and turning on the SWG?.?.?.?
Any idea what your cya was when you closed last year and also, have you had it checked this year? What did you use as your source of chlorine last year? Go ahead and put the bleach in this evening after the sun is off the pool. Test it again early in the morning and see how much you lost overnight and report back. I'll let someone else address your questions about the SWC.
We just filled it up last year and put algeside <sp?> in and something else. This is our first year opening it.
You can go to the pool store, and get their test. But do NOT buy their stuff, with one exception. If they show that you have stabilizer (CYA) below 50 ppm, you can let them sell you enough to raise your pool to 50 ppm.
They will want to sell you all sorts of other things -- that's the purpose of those testing program; to sell chemicals, including many you do NOT need, and some that will actually make your pool worse. We even have a word for what they'll do to you: "you'll get 'pool-stored'!". So, let them test, but just say no to the rest!
(Don't tell them about visiting our site, or using bleach -- with many pool people, it will set them off on a rant if you do. And, you'll need your pool store for parts and some chemicals, so don't burn your bridges there.)
So let them test -- take fresh sample in a closed bottle, with no air left in it. Do NOT let the sample sit in the car. Buy your CYA if you need it. (Testing does cost them something.) Then come come and test your pH and chlorine levels, and post BOTH sets of results here.
Meanwhile, add 5 gallons of 6% bleach to your pool, this evening if possible.
Ben
Ok, Good advise thanks Ben.
I added two bottles of liquid chlorine it says it is like 12% so thats close. I'll run a sample out tomorrow or Tuesday and see what everything is sitting at.
On a side note how long does this "restricted" status stick around and moderating my post prior to posting.. lol trying to answer in a quick fashion isn't working well.
You can exit restricted status in two ways:
1) Subscribe
2) Post successfully a number of times. (No recipe given -- spammers apparently find, and share such recipes.)
Ben
Ok, sounds good.
I added CH last night and added about 10 bags of salt today. Waiting to turn the SWG on till tomorrow am to let the salt dissolve all the way.
Well out of curiosity I took a bottle of water to our local pool place and tested it. The SWG was reading 1900 and I though that had to be wrong, well it wasn't. I added the additional 4 bags that I had sitting here and it is just shy of 2700 so I need to add another bag. I just need to know how many PPM a 40# bag of salt will bring the pool salt level up to.
Here are the results they are obviously low due to us just getting the pool started for the first time. She did say that I need the stabilizer (8#) to add to the pool so I might pick that up there to keep on good terms.
FC .3PPM
Total Chlorine .4PPM
Combined Chlorine .1PPM
Ph 7.1
Hardness 54PPM
Alkalinity w/Stabilizer 0PPM
Cyanuric Acid 8PPM
Copper 0PPM
This is what she suggested that I do. 1st add 65# of hardness increaser let that mix around for a while and then add 56# of alkalinity increaser to the pool. Then when the levels are all correct add 8# of stablizer
Scratch that first salt level reading. I read it today and it is at 2800PPM.
What is the temperature of your pool water? I had a "Low Salt" light when my water temp was approx 45° F over the winter. It sounds like you're doing the right thing, add a little at a time and TEST, TEST, TEST.
SS1304
The 40 Lb. Salt bags that I buy have the words "480 ppm when dissolved in 10,000 gallons of water". Using this formula as a baseline, If you have 27,000 gallons, one 40# bag should increase your PPM's by approximately 175 ppm.
The actual amount of water in the pool affects this formula.
If four 40Lb. bags took you from 1900 to 2800, I would say each bag is raising your PPM's by approximately 225 PPM. This tells me your actual water volume is closer to 22,000 ish Gallons.
Exactly what is your desired Salt level in PPM's?
Hope this helps.
BTDG
I added 12 45# bags in 26k gallons, ended up at 2500 ppm...
thats about in line with 225 a bag!
madwil
You sure they were 45 Lb bags, not 40Lb bags?
