Ok, folks... I've got a bit of a mystery on my hands, starting with a pool full of clinging green algae.
It's a concrete / plaster pool of about 9000 gallons, with quite a bit of green algae on its surfaces. It's chlorinated with a Rainbow Puck-type automatic feeder.
I've shocked it three times over the past two weeks with about 2 pounds of granulated chlorine each time (plain Cal Hypo, not the Dichlor or Trichlor type)
Very limited improvement seen in the algae.
So, I tested my CYA level and was surprised that it was ZERO. I mean, 30 seconds after adding the reagent, the water was still clear as a bell. And this is brand new reagent bought yesterday.
So yesterday I added one gallon of Instant Conditioner, where the label says that 1 gallon will increase CYA in 10,000 gallons to approx 30ppm.
This morning I tested again, and the CYA is only a trace. It does cloud up, but it's certainly not 30ppm.
What's going on?? What's happening to my stabilizer?? This is the first time in 13 years I've had to add stabilizer! Well, actually I had to add stabilizer once about 6 or 7 years ago when I did a total drain and refill. But you know what I mean.
Usually at the beginning of a season I do a partial water exchange to REMOVE high stabilizer.
I'm puzzled, and I'm afraid maybe something in the water is interfering with the CYA test, and I may be making the situation WORSE. I'm fairly sure that there is, in fact, NO chlorine after 24 hours by using both a DPD and OTO chlorine tests.
