Chlorine Causes Cancer . . . or Not!
News reports, with headlines like "Swimming in Chlorinated Pools Causes Cancer", are being published, following scientific publication of a Spanish study of swimmers using INDOOR, PUBLIC swimming pools.
I'm posting these links and attachments now, but will save the full comments till later.
But briefly, in all the articles, the bogus content comes from two sources. The very worst material, such as from News4 or Discovery, comes from the reporter's own additions, omissions or editorializing. For example, the News 4 reporter implies in the lead that this study has relevance to swimming in OUTDOOR pools. The second source of bogus content comes from editorial quotes from either the scientists themselves, or from (in this case) one of the managers of the sponsoring organization.
The full study, entitled "Genotoxic Effects in Swimmers Exposed to Disinfection By-products in Indoor Swimming Pools", is here: http://ehp03.niehs.nih.gov/article/f...%2Fehp.1001959
The official summary is rather moderate:, "Our findings support potential genotoxic effects of exposure to DBPs from swimming pools. The positive health effects gained by swimming could be increased by reducing the potential health risks of pool water."
A relatively accurate and more comprehensible, if still overly dramatic, summary from Science News Daily is here:
DNA-damaging disinfection by-products found in pool water
And, here are a couple MSM articles with shrill "making it bleed so it can lead" headlines:
A really, really bad article from a Jacksonville, FL TV station, News4Jax.com:
Chlorinated Pools Increase Cancer Risk
From Fox News, a bad headline but not quite so bad article:
Studies Show Swimming in Chlorinated Pools May Lead to Cancer
From the LA Times, what appears to be by far the best summary:
Chemicals in indoor swimming pools could be harmful, three studies show
And finally, a truly horrendous article from Discovery.Com:
Chlorinated Pools May Increase Cancer Risk This article references a previous really bad article, entitled "Swimming Pools Kept Clean by Going Green". Some of y'all might want to take a look at that one, to see all the 'bogousities' present there.
(FYI, I am interested in use of biological methods to clean pool water -- but I'm pretty gun-shy, since over the years almost every "NEW" pool idea has turned out to either be a bad idea, or far, far less significant than what folks said initially.)
More later. I've archived all these articles so they will remain available.
Ben
"PoolDoc"
=> psart
Re: Chlorine Causes Cancer . . . or Not!
space holder for comments to added later.
My problem with the study was noted by your second citation: There's insufficient information on the content of the pool water. FC look like it was 1.17ppm but there's no mention of CC, or pH, T/A, CH, metals, or other content of the water other than a very oblique comment about keeping the water free of contaminants, whatever they mean by that.
Nor was there a discussion of the variations in the water for each swimmer.
It's kind of like comparing 1/4 mile times of cars, but not allowing for barometric pressure, or whether sometime the course was flat and sometimes they had to go uphill or whether the surface was dry and sticky or a bit oily and slippery.
Still, it's a start. But as Ben posted before, what's the risk of water-borne diseases WITHOUT Chlorine?
There were a series of scientific papers released about the same time and a flurry of media reports on them. I've written a post about it here, but as Ben writes above, the pools in the study are very different than typical residential pools because they were indoor pools (so no UV from sunlight and relatively poor air circulation), were public pools with high bather load, and likely did not use Cyanuric Acid (CYA) in the pools.
Virtually every scientific study done investigating Disinfection By-Products (DBPs) has found that they are roughly proportional to bather load (see Fig. 1 in this paper as one of many examples). Unfortunately, the investigators did not identify the specific bather load of the pools used, but they were likely to be high since they were public pools and had high DBP levels including Combined Chlorine (CC).
The chlorinated pool in the mutagenecity study was 33 x 25 x 2 meters in size so around 436,000 gallons with a Free Chlorine (FC) level of 1.28 mg/L, monochloramine of 0.29 mg/L and dichloramine (that is likely to really be chlorourea) of 0.38 mg/L (so combined chlorine of 0.67 mg/L). The THMs in breath study used an indoor pool that was 25 meters long with the pool located in a sports center with an average Free Chlorine (FC) level of 1.17 mg/L, dichloramine of 0.43 mg/L (monochloramine wasn't measured but was implied in the study to be roughly the same level). The genotoxicity study used an indoor 25 meter pool with an average Free Chlorine (FC) level of 1.17 mg/L. This implies that this study used the same pool as the THMs in breath study.
I have a Breakpoint Chlorination spreadsheet where a steady-state of 0.3 mg/L monochloramine with 1.3 mg/L FC (with no CYA) can be achieved with around 0.7 mg/L Nitrogen per hour from ammonia alone in sweat and urine (if I run the model with urea assumptions, the implied bather load is even higher). Typical assumptions for the amount of sweat and urine in swimming result in around 800 mg Nitrogen per bather per hour. So this implies around 1140 liters per bather or around 300 gallons per bather. This is unlikely (seems too high) so there are probably other sources of nitrogenous compounds (or people were urinating in the pool), but it still indicates that the bather load was probably very high in these pools -- at least 5-10 times higher than in residential pools.
In the mutagenicity paper, it was noted: "We found a greater number of DBPs in the chlorinated and brominated indoor pools studied here than were found in chlorinated outdoor pools (Zwiener et al. 2007), which was not surprising, considering that DBPs can be volatilized or photolyzed (Lekkas and Nikolaou 2004) in outdoor settings." This is an important point. The greater air circulation and the exposure to ultraviolet (UV) rays of sunlight in outdoor pools significantly reduce the amount of DBPs, probably by at least a factor of 2-5.
Finally, the studied pools very likely had no Cyanuric Acid (CYA) in the water so the active chlorine level was far higher than in pools with CYA. The pools in the study had an FC of around 1.2 ppm while pools at roughly the "target" level in Ben's Best Guess CYA chart have the same active chlorine (hypochlorous acid) level as a pool with roughly 0.1 ppm FC and no CYA. So the pools in the study had over 10 times the active chlorine level of residential pools that use CYA which would have every (elementary) reaction that chlorine participates in be over 10 times faster. The breakpoint chlorination models all demonstrate that this higher active chlorine level leads to a greater rate of production AND total amount of very irritating and volatile nitrogen trichloride (this is also described in this article).
The bottom line is that outdoor residential pools are much, much safer in terms of having much lower amounts of disinfection by-products (DBPs). For commercial/public high bather load pools, I recommend that they use a small amount of CYA to lower the active chlorine concentration, so around 4 ppm FC with 20 ppm CYA to achieve roughly the equivalent of 0.2 ppm FC with no CYA, and that supplemental oxidation (UV, ozone, non-chlorine shock, enzymes) be used. These two work together since the lower active chlorine level gives precursor molecules more time to be exposed to the supplemental oxidizers and also gives them more time to volatize before reacting with chlorine.
Richard
My favorite of these--I think it was the one about using moss--was the one that stated that if there were no iron in the water, then microbes couldn't grow. Hmmmm--maybe we should re-think iron filtering----NOT :rolleyes:
O.K. riddle me this. Municipalities across the country regularly add chlorine to our drinking water. Shouldn't we be more afraid of cancer from DRINKING the chlorinated water as opposed to SWIMMING IN IT?
Yes and no. Generally speaking inhalation of volatile compounds can get into the bloodstream more readily than through drinking of water that has to go through rather harsh acidic conditions in the stomach first and then on to differing levels of absorption mostly in the small intestine where digestive enzymes can break down some of the chemicals. On the other hand, the quantities of water that one drinks is higher than the amount of by-products one inhales.
Drinking water is processed through multiple stages that intentionally try and reduce organic precursors before the later chlorination stages. Filtration (including coagulation), aeration, and non-chlorine chemical processes are done before chlorine is added for disinfection. The final stage will add either chlorine or monochloramine with more water utilities moving to the latter to avoid more disinfection by-product formation downstream in the distribution system and to have this residual protection last longer.
Nice analysis. Have you considered writing to the editor of the various publications quoted above refuting some of the details of the study, or formally conducting your own and publishing the results?
Just remember "Man Bites Dog" is a much better story than "Dog Bites Man"
I wasn't really refuting the studies -- just explaining them and their context relative to residential pools. However, some of the news reports were either exaggerated or misleading. There are already some letters coming from other organizations. Since I am just a pool homeowner, I would have no credibility, unlike others such as NSPF, APSP, etc. who have posted comments or given quotes.
BTW, I gather that being raised on Mother's Milk leads to cancer, but, then again, so does being bottle-fed on formula.
