First, thank you for this forum. I just registered for 1 year...the least I can do for the info I have already received from just one day.
We just bought a house in the country with a 15x30 above ground pool, and I know nothing about pools (well...not until yesterday after I spent several hours here). Pool looked great when we moved in about a month ago and I have not done much maintenance. Added chlorine pucks and a little vacuuming. We had a big storm other day and lots of leaves and dirt got in pool. Went 2 days without tending to it and...well it was pretty ugly. A nice shade of green! So, after reading here yesterday I went home last night scrubbed walls and vacuumed really good. I also tested for the first time. Chlorine was at the last mark .5, and Ph was below last mark 6.8. So I added 4 gal. of bleach, waited half hour and added 1 box of 20 mule team (4 lbs), turned pump to run all night, and went to bed. This morning I was amazed! It is nor crystal clear, but it looks 100% better already. Tested this morning and the Chlorine was off the chart. I assume that is ok after adding all that bleach??? And that with the direct sun and 104 temp all day that will come down pretty fast??? The ph however was still at the 6.8 range. My question is do I add another box of borax, or wait a day or so???
Thanks, Robert
