Re: Chlorine Lock ?
Dont feel bad. Consider this all a learning experience that'll only help you later on. It figures your CYA was higher than the prior reading of 80.
If you want to drain, you'll need to do it in steps so you don't damage the liner. Drain leaving no less than about a foot of water at the most shallow end if your pool. Refill, retest, and redo if need be.
Re: Chlorine Lock ?
I have read that you should drain down to the bottom of skimmer and add water back. Do this several times until the water is sufficiently diluted. I guess that will be my next plan of attack. Wish I had done this to begin with. Am I correct in thinking that the CYA reading should be 50 or below when the water is diluted enough?
Two other things...I will never use those 3" tabs in my clorinator ever again (brand new chlorinator I might add!) and I should have bought stock in Chlorox.
Re: Chlorine Lock ?
You have the right idea. You can drain down as much as leaving a foot of water in the shallow end and you should be ok. I would guess you need to do 3x to get close to 50 cya. That is... if each drain equals 25% of your total pool water volume, the first drain will reduce your 130 cya to about 97. The next drain will take it to about 73 and the next to 55. Be sure to run the pump for a couple hours after each refill to mix up the old pool water with the new fresh refill.
You may still find yourself using those 3inch tabs at some point. So keep them handy for when you go on vacation and when you may need to add cya next season. Search the forum for proper storage tips. They will also reduce your pH with use. You reported a 7.2 pH reading correct? The pH test with your FC so high will be artificially higher than actual. To be safe, you may want to retest the pH by diluting it down to a 25% sample. Take a measuring cup and fill 3/4 cup with distiller water and 1/4 cup pool water for a full cup of test sample. Stir and then test the pH. If it reads less than before, your gonna want add some (20 Mule Team) Borax to raise the pH back into proper range.
Re: Chlorine Lock ?
7.4 PH last night. I will start this drain/fill process this evening. Off to a tennis tournament!
Thanks for your continued support and quidance. Much appreciated.
Re: Chlorine Lock ?
You don't have to drain ....... lots of people just live with the high CYA and just run higher chlorine levels to compensate for it. That works, too. At this point in the summer, you might just want to leave it. Some pools lose a lot of CYA over the winter. You may just want to wait and see where your CYA is in the spring when you open and do some partial drains at that time if it is still high.
http://pool9.net/cl-cya/
I am also a little concerned that you may not be doing the CC test correctly. It is pretty unusual to get that kind of a result. Can you explain your steps that you are following to do the FC and CC test so we can verify that you are doing it properly?
How does your water look?
How consistently are you adding the bleach each night to keep the pool at shock level? It has to be done consistently. Doing it every few days isn't gonna work.
Re: Chlorine Lock ?
Agreed, draining isn't the only option.
Re: Chlorine Lock ?
Back home. Pouring down rain here.
I have tested again. Using the 10ml. sample I added 1 scoop powderand it turned really pink then added37 drops of 871 until clear, multiplied number of drops by 0.5 which equaled 18.5. I then added 5 drops of 003 and sample turned light pink. I then added 4 drops of 871 and it became clear. Multiplied 4x0.5 =2
Last added bleach Weds. night. 5 jugs. Then got scared...I have bleach to go in pool if I need to do that. It just seemed like everything was way out of wack. Water is clear.
Re: Chlorine Lock ?
I'm sorry things have been so frustrating.
1. Hang on a little longer. Enter daily test results in the pool history spread sheet. Do NOT test CYA -- it's not going to change, and you'll run out of reagent.
2. Complete the equipment form: http://pool9.net/pf-equip-form/ Try to include your pump and filter models. Once you've got several days results posted, and have have the equipment form completed, I'll go back and re-read this thread from the beginning and see if I can make more sense of things.
3. Keep in mind that draining a vinyl pool is a HUGE issue, and can destroy your liner if done incorrectly.
Re: Chlorine Lock ?
Greetings to my pool experts in the cyber world. I have completed the pool equipment form and have also added my last 3 testings on pool history document and submitted. Maybe PoolDoc can take a look? I think maybe things have improved on the FC and CC front. Adding less and less bleach to get to that 25 number and the 1 CC. Pool is clear. Needs a good vac (to waste!). It looks good. I have not retested the CYA and will not because I will definitely run out of reagent. I did not drain at all and it rained about 1 inch yesterday. Does any of this sound like I might be making progress? Thanks for your continued advice and support!
Re: Chlorine Lock ?
Well if the pool is clear, you're at the last mile of all this. So congrats :)
I'm sure PoolDoc will take a look when he can.
