You have a LOT of patience! :)
I would have told my neighbor, "Suck it, Trebeck!" a long time ago.
You have a mild one, believe it or not. There's no sense going into long tales of the problems I've had with the psycho#@%^& next door to me. Suffices to say, agreement or not, you are using THEIR property and as such you need to be like the ultimate visitor. Doing everything you can possibly think of to calm the situation and make it as painless as possible for them. Get a new high quality hose and nozzle and spinkler. Make sure the nozzle is similar to the one they had. Ask them politely when they will be home that the spinkler could be turned on and make the appointment yourself. Pick up the debris and do it every day - they shouldn't have to ask. Give them a check for the pineapple stuff they listed. Make damn sure the sod is pefect - give him a bag of scotts turf builder when it's done. Believe me, your responsiveness will go a long way to settling the Hatfield's complaints. If you don't, your being the McCoys' and the feud will continue for as long as they live there. Even if you only succeed in making temporary peace, you will be on the right side morally. It's obvious from your reactions to events that you are indeed reacting somewhat negatively. I know how hard it is to not react negatively - be above the fray. Some will never be satisfied and this may be one of those. If you are making all of the good faith overtures, they will probably react differently. As a final note, keep checking on them like senior citizens. Go and ask them - daily if necessary - if thing are ok and work to resolve their issues. In other words, turn the other cheek as often as it takes to get through this. You won't regret it as long as they live there/
On the point of the legalities, keep records of what your doing to keep the peace. If it ends up in small claims or civil court, being able to show you went above and beyond will defray any claims he has. As far as the drainage is concerned, you cannot claim adding the pool and other items has not changed your properties drainage - as a result, he can easily claim you caused problems - it may be incorrect but the change makes it a real possibilty in the courts eyes. If you have to add drainage pipe and a flow out grate or pop up flow out cover do it. Again, in court - being able to say do did everything possible to address his complaints and went above and beyond leaves him claimless.
In my case, things ultimately eroded to the point where the police and the Township Building Department were called several times. Once they saw what I was doing to mitigate the situations, both told me they were surprised how much I had done, apologized to me for the trouble and went next door to tell her she didn't have a leg to stand on and that she should be grateful she had such a good neighbor - I know this because I sat and talked with one of the officers over a coffee on a following visit. If I had to supeona the Officers or Township in a lawsuit, she would have looked awfully silly. I eavesdropped on conversation she was having with a lawyer in her backyard. He told her she could not win with the amount of effort I had put into mitigating her complaints.
Again - stay above the pettiness. Go above and beyond and do not respond by being even slightly negative to their pettiness.
Update -
Well I spent about three hours moving dirt last weekend until they liked it. They didn't like the fact that there was water puddling in OUR yard????
Anyway - they are not talking to us again - since our propane tank was installed above ground. Nevermind the city wouldn't let us burry it - I guess that is our fault too. We have to wait for the home owner's association approval before we can install the fence. Also - the sod is 2 weeks late - all the water here means that it's too wet to cut the sod from the fields and... then with a tropical storm coming - it will probably be another couple of weeks.
I just want to get this finished!
Weel, the neighbours didn't vote for the guys who won't let you bury the tank, so it MUST be your fault!!!! What a pain, I would prefer to have a tank buried myself but if you can't do it, you can't do it.
DaveD has a good perspective though. Make them be the unreasonable ones and they won't have any sympathy from anyone.
The HOA let you install the pool without approving the fence first?
The HOA understands that a fence is going to be required when putting in a pool, however, tehy feel tehy have the final say as to how the fence should look - another reason I absolutely can NOT stand living in cookie cutter subdivisions, they slowly kill your individuality!
Move to the country - the air is fresher, the people are happier, your neighbour will HELP you instead of fight you and if you do end up with a big RUT in your lawn, he'll only join you on his dirtbike to help make it even BIGGER!
Originally Posted by matt4x4
If I could afford the big house, the pool, on the land I want - that's where I would be. Unfortunately - I took the big house and a pool over a small house/no pool/ and a large yard to mow:p
Originally Posted by Jeffski
Wasn't planning on the fence until the neighbors started getting all upset - now we think it's the best. We got the pool approved by the HOA in November - we closed on our home in December (it was new construction), sold our old house in May and then started construction on the pool. Figured out in July we needed the fence.
Originally Posted by Simmons99
Now THERE is the best news you've had so far. Keep it that way. You aren't going to please these folks no matter how much you exceed your legal and/or ethical obligations. Keep doing the basics to restore their actual property to its pre-pool condition. Don't suck up anymore (the wine) and don't act overly eager to please them. Remain pleasant (grit your teeth) and civil but keep your distance and generally treat their more outlandish requests as amusing and mildly annoying.
These folks are always going to be nuts, and possibly your neighbors for a long time. If they are going to feud, let them be the only ones engaged in it. Enjoy your pool and good luck with this whole mess.
