Silly getting stressed over a pool, right???
BUT I rather have a CYA of 30-40 and only need FC of 3-4....
How much bleach?
"In your pool, a quart of 6% bleach will add around 2.5ppm of chlorine.". Test your chlorine with your kit, and add whatever amount is needed to get back over 5 ppm, using that statement as a guide.
Unfortunately my DPD powder is almost all gone..did not last long,,Leaving on vacation in a week and son will be testing, hopefully with regular kit. According to Dave, he should put in about 4 cups bleach to keep it over 3. Is all this still right with CYA so high??? I think I will test that again Wednesday night. Could CYA go down by itself???
Oh gee this is getting too complicated.............waaaa
I think you're making this harder than it really is...all your son should do is test the water, see what the result is, and then add bleach to get it back over 5 ppm. If he needs to add 1 ppm, he should add 2 cups. If he needs to add 2 ppm, he should add about 4 cups. If he needs to add 3 ppm, he needs to add about 6 cups. These are estimates, but they will work to make it as simple as possible.
If you stop using dichlor, your CYA will eventually decrease via splashout or water lost during filter cleanings--but it's going to be slow. Plan on keeping 5 ppm of chlorine in the pool for awhile...
Redid CYA with same water and solution..looks like 50 now which would make more sense. Again, will only be able to test with DPD powder for another 2 or 3 days..Will order more..BUT With regular test , ONLY REGISTERS UP TO 3 ppm. So what do we do???
Here's how to force it to read higher...
http://www.poolsolutions.com/gd/how-...d-testkit.html
My DPD test will arrive Thursday but my son will only be using the OTO if he remembers. I am retesting everything tomorrow night and will repost the numbers so I can finalize my plans.. Tonight put in 3 cups bleach only
What were your FC, CC, and last night? What day are you leaving?
Please also do pH. 3+ OTO is what I'd like to see. We can run the recipie for your son for a couple days and see how it goes. Thanks.
