Kit is here! Readings:
FC 18
CC 0
Alk 160
ph 7.8
Hardness 175
CYA 100
Let me know what you think-pool is clear
thanks
FC 18
CC 0
Alk 160
ph 7.8
Hardness 175
CYA 100
thanks
Looks pretty good, except that CYA is awfully high. When you get to the point where you're ready to let your chlorine come down,do NOT let it go below 8 ppm. With a CYA that high, you;'re going to have to maintain it between 8-15 ppm in order not to get algae. This is a long thread, and I haven't looked back yet to see if partial drain/refill has been suggested, but it's still early in the summer, and it sure would be a lot easier to maintain the pool if the CYA weren't that high. DEFINITELY no trichlor pucks or dichlor shock for you!!
Otherwise, TA is a little high and pH is as well, but that puts you in a great position to lower both using muriatic acid. The process is here: http://www.poolforum.com/pf2/showthread.php?t=191
Otherwise, things are looking good!!
BTW, I deleted the duplicate post--when I moderated your last post in, there were two copies. Since we have to moderate all posts in, if you post something and don't see it show up immediately, wait a bit before reposting--it's probably in the queue.
If it's a vinyl pool then Alk is not a problem. If it's concrete or plaster or tile, you'll need to lower it.
With a CYA of 100, you'll have to maintain your FC between 8 and 15--you're now a 18 so you are fine.
pH is a little high, but that may be an artifact of the high FC of 18--but it's still in normal range.
About the only thing you should do is wear last year's bathing suits as the higher level of chlorine may fade them.
In short: For a high-CYA pool, your numbers look pretty good. Try adding to drops of the # 7 reagent to your pH test before your add the 0014 reagent. That's chlorine neutralizer and two drops neutralizes about 10ppm of FC--you have nearly 20. You may get a lower pH.
If your TRUE pH is lower and you have a vinyl pool, AND you are willing to maintain a high CYA pool, then I think you are just fine and good to swim.
Thank you all for your help. I am waiting for chlorine to drop to about 8-10 before I let grandkids swim. I have owned this pool for 23 summers and I never, ever had anyting like this happen before. Grateful you were here to help!
Aylad I have already drained 1/2 of the pool about 1 week ago!
It has been in the low eighties and high ninties here with a few storms. Can you make a guess as to when my chlorine will drop to around 10?
Have a blessed day!
I know that you drained a good bit--but the CYA numbers that you've posted are still very high. So you'll either need to drain/refill some more in order to lower it, OR keep your chlorine levels high (8-15) in order to compensate for it. Which decision to make is yours--I don't know how feasible they are to you.
I would say by late today or tomorrow. It doesn't take long after a rainstorm!
If you have cc does that mean something is trying to bloom? My FC is now down to 11 and cc is .5 We had bad storms yesterday and I have not had a chance to vacuum bottom of pool. Do you think that is why my cc went up to .5 from 0?
Thanks for all your help. I have learned so much about pool chemistry!!!
The rain probably dropped some debris in the pool which can cause a little CC. As long as you are no higher than 0.5 you are ok. Or, you can go ahead and shock the pool and that will take care of it.
CC was o this AM!!! My test vial was dirty. Washed and dried it and cc was perfect!
Question is my fc is now 8 i do not want it to go lower. How much chlorine should i add tonight to get it up to 11 since i am losing about 3 ppm each day with this heat and sun.
thanks in advance
In your pool, each quart of 6% bleach should add approximately 1ppm of chlorine. So that makes it easy to know how much to add --- 3 quarts.
I slightly remember years ago I read somewhere that if the pool is calm for a while that the CYA will "float" to the top and then you can remove that water, e.g. via the skimmer, thus removing a higher concentration of CYA. Also I believe that the article/post/whatever it was suggested siphoning off the top while having a water hose in the bottom of the pool slowly adding water and "pushing" the higher concentration CYA water towards the siphon.
About a year ago a co-worker told me a pool store guy verified the idea that the CYA will stratify in a calm pool and that to remove the most CYA let the pool settle and then remove the water from the top.
I have been meaning to test my water with the pump running for the "normal" cya level and then after letting the pool sit overnight test the water from a couple inches and then a couple of feet down to see if there is any difference.
Anybody else hear anything similar to this?
