Re: Baquacil to Bleach conversion (help needed)
Hi Rev,
The stabilizer (CYA) bottle should have some guidelines on it but I would say that adding a 4 lb bottle should give you a max rise of 20 ppm (I would guess it would be a little less) so that's probably a good amount to start. You could buy extra while you're at it to adjust later as necessary.
Also, I have seen in other threads that some conversions need polyquat to get the water crystal clear. Since you mention a green tinge but otherwise are under control, you could try this but I don't have the firsthand knowledge to be able to say it will help for sure, I'm just going by what has worked for others.
Congrats on your conversion.
Peter
Thanks for all your help...I think we're done. The water is crystal clear and blue. We kept the levels up to 15ppm through yesterday morning and now, 24hrs later, through a hot sunny day, they're still at 7.5ppm. Anyone disagree with the notion that I'm done??? ...and what would happen if I'm not totally done??
Please note I have not put anymore chemicals in the pool (i.e. CYA or algeside, etc.).
REV
It sounds like you're done to me. Keep testing regularly and I would suspect that if there was anything left you would see your CC creep up above 0.5 and that would be the sign to shock again.
Congrats on your conversion!
Peter
sounds great -- congrats!
Rev,
You'll remember that I felt like my pool was done and it still had a greenish tint to the crystal clear water. Well, about a week after changing the sand in my filter I've noticed my pool water definitely looks blue so I guess it still had a little bit of change left to go.
Also, I know you were discouraged about it taking so long for your conversion to be complete but that may have to do with the fact that you're not usually home during the day like I am. I was able to check my chlorine level every hour if I wanted and just kept topping it off if needed.
Congratulations! Now, go enjoy your pool!
--Deborah
Congrats on your pool conversion. I think I'll be starting mine tonight, if I can convince my hubby.
One question and it's probably a stupid one.
I'm guessing you run the filter 24/7 through the conversion process??
Lizzie - it is best if we keep all your questions about your conversion within one thread. Since all of your information about your situation is in the other thread, let's use that one. Looking forward to hearing of your progress.
