Watermom,
I'm using the hth 6 way test kit I found at Walmart last year. I added half a box of borax last night with the usual bleach and this am the ph was 7.2 after pouring all last night. Chlorine was 5-10 dark yellow.
Pool is holding some chlorine as I go from very dark yellow 5-10 during the day( morning reading) I then add another 182 oz of bleach after the sun goes down to get me above the test kit limits . I add bleach when the level is at the 5-10 .I'm staying pretty high most of the day. Do you think I should add a second bottle at night to keep way above the test limits? I didn't locate the distilled water yet I'm in a rural area so I have to hop around different stores.
I added the other half a box of borax this morning and added the next dose of bleach did a retest about an hour after the additions and the chlorine is orange/ red an the ph was purple 8.2 is the highest on my kit so probably above that but I just added the bleach so not concerned it will come down a bit later.
So far I have put in the 4 lbs of cya and 4 lbs of borax. I'm brushing daily and was only able to vacuum 2 days ago when I took a ton of stuff out of the pool. Water is a very light green looks like lots floating, running the filter 24/7 and switching out the cartridge daily. New Unicels will be here by wed so hopefully I make more progress. I'll keep vacuuming as the weather permits. Don't want to be in the pool with a metal pole during a thunderstorm lol. Any other suggestions to clear this faster? I did add a dose of clarifyer earlier in the week per Bens suggestion. Do I add more? Thanks!!
